Same as the green thing really, a good allrounder just with 4wd and a bit more power!
It's got some cool fruit already including a full T88 kit but I'm going to downgrade the turbo to something more suitable
Weeeelll, well. Looks like I won't be giving any head starts at Powercruise after all. Finally bringing a gun to the knife fight mate! ;)
Edited by R32 TT
What does that even mean? Is this that thing they call generation gap?
Haha I loathe that expression as well! It's like saying "letterbox me". It's for people who dont underdtand that inbox is just a noun, not a verb.
Edited by SimonR32
Yeah still got a bit of time in it at the track, last time I went out was on AD08 street tyres and it was as quick as my old times on R-comps.
The quick GTR's (550-600rwhp) usually do around 64's long track, I did a 66.7 before the cams, vipec and S15 subframe etc so I would hope it's quick now. Also only revved to 7000rpm and 1.4bar at the track so there was probably a bit of time in it. Wouldn't be surprised if it went a low 65 or high 64 as is now... But not to be! (well from me anyway, I'm hoping someone with good aspirations picks it up)
For sale thread :(
http://www.skylinesa...whp-rb25-green/
Edited by SimonR32
  • 4 weeks later...
  • 2 months later...
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
