Ok guys I've done a bit of searching around and haven't really been able to find anything that relates directly to my situation.
My R32 GTS-T puts out about 230 kW on 16 psi and is running the following mods (just nudging stage 3)
Full RB20DET rebuild with upgraded rods and bearings
FMIC
Full turbo back exhaust with performance cat
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
Nistune Chip (on stock ecu)
Upgraded HKS turbo (not sure of model)
Nismo fuel pump
Exedy Super HD Clutch
Question is...WOULD I BENEFIT FROM A SET OF CAM GEARS (AND TUNE)?
I'm very happy with my car at the moment and wouldn't want to lose something to gain something else. Only really interested if it will all be positive after install.
Cheers guys
https://www.sau.com.au/forums/topic/346671-cam-gears-is-it-worth-it/
Cam Gears are relatively cheap these days, so it would be worth getting them and testing on a dyno in different positions,
we have made some response gains with poncams on a GTR,
are you running stock cams?
So having cam gears would also increase boost response ?
Yeh mate, I can't remember the one I have but it made a decent difference, 500-800rpm earlier with boost....
Also, I only have the exhaust side done, I think its only the exhaust cam gear that makes a difference for boost response.
are you sure you are seeing the gains ONLY from cam gear fitting to RB25?
we know cam gears gain power and response on RB26, but from memory on RB25 it is pointless and factory is best setup
Im confused , becuase i really want to get some, I spoke to Trent ( my tuner i trust ) he said to me its pointless.. for my setup.. and my setup is simular to plan-b's mods.
You don't want some , only one. Inlet is best to leave vct to do its job - people have tried to no avail. On exhaust side typically on an RB25DET with stock cams 4deg retarded will improve midrange with poss some small cost at top end.(from personal experience with my rb25det with GCG highflow).
  • 1 month later...
Looks as if a aftermarket exhaust cam gear would be a good move. Intake is probably a waste as people have said.
It's only a waste on a RB25DET due to the VCT, which advances the intake cam 10 degrees pre 4700 rpm or close to MBT.
I can see it being beneficial on a RB20DET which as no VCT. If you have some dyno time try getting the exhaust cam gear dial it back a few degrees and/or get an intake and advance it 1~2 degrees and overlap the power curve.
To all the people saying yes they are worth it, do you have 2 dyno sheets where the only difference is the exhaust cam gear with a tune after each?
I have spoken to a few tuners (Trent being one of them) and they all say dont bother on the RB25. On the RB26 its a different story.
Tuners are the only ones that would have seen many cars where the only mod they do is cam gears. Most other people would combine them with other mods and then say wow the cam gears worked well when in fact its not the case.
We're talking RB20DET here mate.
I've disregarded info specific to the RB25s as, like you have said, aren't reknown to yielding gains from cam gears.
I've come to the conclusion that it would be one or the other (cams or cam gears) on the RB20DET. I will be doing cams as people agree that Pon Cams come perfected, no need for cam gear adjustments/aftermarket gears...
I cant find any posts here that arent specific to the RB25? Not sure where your reading.
Apologies I did miss the RB20DET at the top, I just saw that all the responses were to do with the RB25.
I have also heard tuners say, its only worth it on RB26's, not sure if they are including RB20s as well?
Haha not sure where your reading either bud.
From what I've been told today, I'd say Poncams for a decently modified RB20DET will be most beneficial, both in low down torque and boost response.
Edited by plan-b
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
