yeah they will happily make power to 9000rpm on your setup :)
Remember the dyno dymanics stuff always looks more responsive as the extra weight of the rollers adds extra load, we just spent a fair amount of time liaising with another shop and found the normal baseline run we do of 9sec from say 1500-7000 has less low end load applied. So its more equivalent to 12-13 seconds.
Jesus, might happily make power... and break a oil pump, shatter the valvetrain and snap a few rods?!?
I'll try get another run when the guys get back from the xmas break... Would doing a 1500-7800 run over 9sec be similar?!? Obviously with this turbo it wants to rev a little more :)
haha i said turbo will be happy... nothing about the engine... dont think id try either :)
1500-7800 @ 9secs (on the lowest power correction mode so it gives me conservative results SAE J1349 (2004)) is what i use to tune (after all the f3 and f2 tuning is finished) then i do a 14sec run as a heavy check @ the end. Customer never gets a 14sec printout as its unrealistic response wise.
This 9sec run gives near on identical peak rwkw to all the new Dyno Dynamics but without the inflated low and mid. The 12-14 sec run will give you the same response as the DD but about 4rwkw more peak.
WOW great results. i have also brought this turbo. Similar bolt on parts spec, just getting a few more parts together. Will be going on a Neo spec Rb25det.
Simon did you have you 6 boost made specialy? i have trial fitted my turbo using a matse 6boost but it fouled on the cam cover.
will be getting tuned on a mainline, i will post results for a comparison, but not till late jan
great work....
great work....
No I didn't have the 6boost made custom and the housing didn't foul when we put it on but when we rotated it to the desired position it did start to hit... So the angle grinder knocked a few mm off the cam cover (I'll try to remember to take some pics for you)
What fuel are you going to use?
Cool might give it a try for a comparison in the new year, cheers for the info AND the advice on the turbo!
OH ok maybe the manifolds vary a little. Or Neo head slightly different at exhaust manifold flange? wont be to hard to sort out tho
will do a tune on 98 and e85.
Went for a fairly big drive tonight...
Loading up 4th on a straight road from 3000rpm will get 1bar at 3500rpm :) It was on a boost setting of 1.45 bar and it was hitting peak a bit before 4000rpm
I'll try take some videos next time I go for a drive.
some great info here!
Keep it coming!
Oh was his E85?
I thought it was PULP.. My bad if thats the case!
nah that was pulp
on e85 he made the same power as he ran out of injector.... was only running 740's
Did some more "testing" on way to work today... Should be reasonably accurate as I have both digital and analogue tachos and boost gauges.
Loading up from 3000rpm in gears;
2nd = 1bar at 4300 (very hard to judge because it start's frying tyres)
3rd = 1bar at 3800
4th = 1bar at 3500
5th = 1bar at 3300
Edited by SimonR32
Just had a look at my turbo and it is actually the TE/TD06SH-25G Not T67 Very similar but Turbine Wheel: 58.8 / 67 mm 12 blade VS Turbine Wheel: 54 / 61 mm 11 blade, compressor is the same. Will be intersting to see the differance.
Anyone got any idea??
Simon hows the boost between gears? does it drop much? or just stays on?
Edited by DR30RSX
im tossing up to get the kando dynamics td06 25g or this t67 25g what would u guys recomend
+1 for vids:)
T67-25g
Mine is the 11 blade one which is the same as a Genuine Trust T67.
That turbine wheel size isn't really "similar" it's actually a lot bigger! If I was you I'd sell the one you have and get one like mine.
No boost drop on mine at all even when slowly changing gear to protect the box :)
Td06SH-25G in theory should spool earlier but fall over earlier in the top end due to the larger turbine.
Same front and bigger rear means it will spool slower but make a bit more top end. I think Trent wrote somewhere that the extra lag was not worth the little bit of extra power they make.
Edited by SimonR32
Yeah i was going to write some but i have no first hand experiance only what i have read.
The TD06SH should be laggier dues to the extra inertia of the wheel and the fact that the wheel is less restrictive due to (amongst other things) it's bigger exducer. The filp side to this is that it will make more power due to it being less restrictive.
From what i have read (and Trent would have more to say on this) the SL2 version of the turbine wheel used in the T67 was designed to be used with smaller capacity (i.e. SR20's etc) engines in an effort to make them more responsive but the flip side is that they will make slightly less power.
Edited by D_Stirls
Fair call on the response thing. I figured that the larger wheel and extra blade would help tesponse. But when you mentioned the extra weight and larger. Exuder it clicked that I was thinking ass about. I was taking the extra blade area into consideration only. Does anyone know of a 12 blade l2 turbine wheel size. Would make for an extra responsive 20g setup. But might involve to much f**king around. I might measure my kkk k27 turbine wheel tomorrow and compare......wow that took forever to type on my phone while drinking beer lol
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
