Stripey horse, seeing as you are going to need a custom manifold anyway.. Why dont you get something like the GTPumps 20g SL2 and get a 6boob with no gate attachment and an evo flange?
Response on that would be balistic and you should net the higher region of 2xxrwkw
A link:
http://cgi.ebay.com....=item3f0595cb7e
I have driven these on evos.. They are scary. I dare say a J-pipe would suffice and would be CHEAP too.
Like this:
http://cgi.ebay.com....=item1c17f04f9e
It would obviously not need a gate.. Can be low mounted.. And can be made a lot cheaper than his price. Keep in mind stock manifolds can support over 300rwkw.
2nd = 1bar at 4300 (very hard to judge because it start's frying tyres)
3rd = 1bar at 3800
4th = 1bar at 3500
5th = 1bar at 3300
Thats impressive! I actually think thats about the same as what I get - got any vids?
I am sure mine would be a bit better with better manifolds etc, but still for a cheap turbo that can flow that well... hat off.
What I don't get is why so laggy on the dyno plot? Surely the dyno run doesn't last as long as you get through 2nd get with that good spooling? If I stand on the throttle at 3000rpm in 2nd I don't get a lot of time...
No vids yet, might go for a drive today and see what I can get :)
nice video man
really pulls hard from 120-220 lol
Under a grand, get one and pop it on your car lol
Weve seen you go thru the paces trying to find a turbo you like (back to a 35R I see)
haha yeah mate
running the gt3582r with .82 at the moment only on 19psi
but i think my car has some other issues... only just fixed one big one which was inlet manifold leaking coolant into the cyclinders and causing it 2 run like shit haha..amazing what $90 worth of machining can do and a $80 genuine gasket
new ecu and hi mount exhaust manifold are on the books for decent power
Video looks really good, too much glare on the gauges (maybe the crap monitor I was using) made it hard to make out, looked a bit like you were backing off just before 1bar but it puts across enough to make it clear it builds boost solidly and goes like the clappers.
Very very nice - best cheap turbo I've seen in action so far, potentially one of the better options out there fullstop really. Whats the rest of your setup?
Yeah my shitty camera and recording skills are fail :(
All the pulls from 3000rpm went over 1bar except the first one which went 0.92 (I know this because there is a peak on the Greddy Profec B Spec II)
Check out build thread in signature, I think it's got most my setup
Edited by SimonR32
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
