So can somebody who has bought or contacted Kando ask about the 20G-XTR billet wheels and ball bearing, water cooled centres that the US STI gusy etc are starting to run???
If he can use his shaft and turbines on those compressor wheels and cartridges with my Greddy housings...lol could be a killer hybrid
Come on dude.. Do you really think such ordinary changes to the thing will alter it that much?
I whole heartedly believe manufacturers would have adopted these technologies 50 years ago when they became available if they were truly that useful.
Read the HG thread, he built some ballbearing turbos then scrapped them because the difference was negligable.
I bought some braided oil and water lines to suit a gt35r on rb25det from Kando Dynamics last week. They were only $80, arrived in record time and look and feel the part. Certainly not "cheap ebay crap" as some have suggested. I'm pleased already and I'll comment more once they are in use.
I hate all this microtech hate I use one with no problems only a little idle hunt everynown and then my car still goes when I put my foot down
Doesn't stop it being a featureless package that has crappy software though. I could put a blow through carby setup on my skyline that would work 'no problems' as well, doesn't mean it wouldn't be shit.
What about when you turn your AC on, does it even have idle air control? If it does does it support AC ?
Edited by Rolls
A bloke I know has LT12 on his ballistic gemini. I downloaded the software from the site to have a look at his tune and the software was substandard to say the least.
Remapping the standard computer with one of those crappy eeprom flashers would be better than a microleb.
The billet wheels are meant to be lighter, and flow more for no increase in diameter. How is that a bad thing? Also the water cooled cartridge is a thing I would like as well.
Dont get me started on BB vs non-BB, I was saying there was more to a turbo then being BB back in 2003 when i went my TD06 instead of 2835 and i copped years of flack for not going HKS but instead going "TRUCK TURBO" {lol, and proud}... so agree on BB meaning little. But a newer compressor that they seem to rate for an extra 20hp that would mean better transient response ... why wouldnt you ask for it...ditto the water cooled centre?????
...that all said, if there was only a few dollars in it, wheels, housings etc all the same....I would still like a BB centre over a plain bearing turbo. Provided the cartridge is of good quality
I recently got a set of braided lines from Kando as well and was quite pleased with the cost, quality and speed with which they arrived.
Being honest, I have seen water cooling an 'optional' core make an ENORMOUS difference to response. I do not know if that was a one off case or if the same can be expected elsewhere though.
Yet I think of it this way, the 20g is a good thing... I consider it to stay a good thing in its original form... What you are suggesting is that they have bored the wheel out to allow more airflow.. Its now a different compressor wheel all together, just in the same size and trims. It is not engineered to be that, it is a 'tweaked' version.... Hopefully a good thing. Yet again I think Stao has tested the same thing and found it to suffer in response (bored out the wheel surface area) read the damn thread!
However if your Trust items are oil only, maybe give a Kando a shot as they come water cooled.
Yeh, the compressors are meant to be new and billet. Some of the US guys say they are mainly a Garret turbo so who knows where the 20G name basis comes from. Some inducate its a TD06L2 turbine with Garret centre and custome compressor...I cant really find out to be truthful.
I want to see you build a blow though setup on a skyline with no problems..:), you'd spend half you time ringing a towtruck to pick you up and draining the motor of fuel because the carby seals let go, haha
cheers
darren
Don't have air con so doesn't bother me
Mines not piggyback it's hard wired in and I'm running VCT fine so I should have that prib when I'm working on mine electrically I undo my battery so there is no power to it at all
Yes well I needed to test if I could force the VCT to click on as its not working, and drive it to gauge the difference. Yet the switchable earth touched ground while I was testing and did a lot more damage than I expected. The stock ECU is fine, just the voltage spike it created rooted the microtech lol
Point is it is a downgrade from the stock ecu and there is no good reason to buy or use one.
I wouldn't say that. My mates gemmi put out 200 rwhp at only 12.5 psi. The engine is newly built and will be eventually be wound up to over 30 psi.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
