If you look through roys build up the has the turbos side by side I'm sure the greedy version but they are very similar to the kandos you can see the size difference in the turbine wheel
Edited by Bsa
I will be getting one of but can't until I get back from Thailand in janurary as money is tight. That's why I'm researching on them as I want to get the right one the first time. Just curious at how similar the to turbos will be seen the pics side by side just wondering what would be like on power curve etc
Any body done back to back testing between the SL2 and the td06h-20g
Two near identical setups on same dyno and same tuner and no difference. the L2 was a tad worse...a tad. My car was a little more responsive and made something like 1.5rwkws more...so variable is exhaust, engine health etc. Jack difference in the turbo...and both cars were recently lapping bumper to bumper at Winton so both about the same
Kris is now running my old spare L2, making good numbers. But i didnt see anything in results that made me want to swap my H for the L2
http://www.skylinesaustralia.com/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page__st__1780
get the td06sl2 20g, it will spool faster and it can flow more than enough
also see this housing for their 8cm T3 internal gate.
http://www.ebay.com.au/itm/Kinugawa-Turbo-Turbine-Housing-TD06SL2-T67-T3-8cm-Internal-Gate-Mitsubishi-/290621301428?pt=AU_Car_Parts_Accessories&hash=item43aa6122b4
just need to have the rear lopped off and drilled out
So after an adjusment its half way there, cheers again to scottynm35 who pretty much cut it, welded it and filed it smooth in the time it took me to smoke a cigarette..:thumbsup:
I reckon I may even be able to get my stock heatsheild to cover the dumps for some extra stealthishness.. :ph34r:
also just incase anyone is interested in what comes in your Kinguwana kit, here it is,
minus the almost metre long oil line which is in my car already.
The oil drain is very small compared to stock, not exactly sure what I will do about that.. Also I was surprised there was no blank plugs in the oil and water holes on the turbo cartridge..maybe this is normal I dunno..
does anyone know what the little T-piece sitting near the copper washes is for..I assume its for a gauge sensor, but not sure how or where it would fit in with the kit :unsure:
LMAO @ TIAL stealthiness, man you crack me up. I wish we lived nearby -_-
and you can get a TFI brass fitting to put a 5/8 bung on the block from autobahn, its a 3/4 from stock i think!
Ye, has a 1/8" NPT fitting for an oil pressure gauge if you want to fir one there
Question for you, does that lip on the mounting face of the V-band flange fit into the rear housing and allow you to clamp it?
Basically I had the same flange but the rear housing was not machined to accept the lip so I had to get him to send a flat one out. A few other guys have PM'd me saying they had the same problem and had to get a replacement sent out too.
http://www.ebay.com....=item43aa6122b4
mines for a rb25 so im going to go the 10cm housing and external gate as the 8cm will choke
and artz ive also noticed your using a 10mm spacer between the turbo and manifold did you need this or did you do it just to be sure as i thought i read on here you didnt need it
Edited by luvpsi
yeah my housing is machined, fits like a glove.. guess i got lucky...
Cheers for the headsup though that could of made life hard had it not fit :cheers:
Thanks for that pic man, I'd definitely prefer to have that seal but mine seems to be sealing fine so far without it...
Scottynm35 did a great job on that housing-gate pipe!
It came up good, I wonder if you could get some sort of heatproof cover like a turbo beanie to cover the wastegate? I guess you will have a screamer plumbed over the heatsheild soon so it wont really matter, when the cops lift the bonnet you will be screwed. lol.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
