splitter stays in the final product looks good and i cant see any problems with defects its alot better then having a turbo reaching for the sky and saying ill take a red one officer. on my set up i had no problems with boost control after my MBC was removed i was using a small gate to 35mm. the 44mm will have no problems controlling things. i think the external gate on the manifold will help the mani flow so much more then without. iv had 260kw though a 38 pipe a 44 could flow over 300+ im guessing
yeah i know il correct myself 200 depending on turbo. it comes down to personal preferance i like it on the manifold as i can put a diferent turbo on if i blow one with the housing your restricted to what turbo can be used. im going to be putting a gt3040 on one of these manifolds and there is no way im welding to one of those housings
External gate is VERY hard to keep hidden. Even custom jobs that I have seen where the intention was to hide the gate, it's still easily spotted if the cops are looking around. if you're worried about cops at all, I wouldn't be going external gate.
I'm not worried about them at all hanaldo I'm just trying to keep it away from first thing to be seen if you know what I mean
And keeping it easy for turbo change if need be for pits
Edited by luvpsi
That's it alot of the time if something catches there eye they will defect you most if the time they don't get there heads in the engine bay just look for something sticking out they are like crows shining things get there attention
I was trying for stealth too with my setup, thats why I avoided external gate for a while, but the boost control is awesome it sounds great.
I have heard both good and bad stories about welding on the manifold, but as of yet I have never heard any issues with welding on the housing of the turbo - provided it is in the correct spot for flow, there is a diagram somewhere about it.
I got mine heat sprayed aswell for stealth+ cooling ( for cooling it was a waste of time, cant remember all up but I think was about 400 for manifold and turbo housing and had to send it away for a week ) but I think the matt balck does help instead of a bright colour.
Decided to make a aluminium heatshield aswell to cover the external gate - which 1. worked way better for hiding things 2. actually functioned as a great heat barrier.
Maybe you could do something like that? Sure, a cop if they were keen could see something, but with the intake pipe ontop and other crap its very hard to tell and just looks like a heat shield... if they are that keen they will get you either way.....
This was while I was finishing drilling the holes for it:
Quoted from the Turbosmart installation manual:
- DO NOT wrap the body of the wastegate with exhaust wrap
- DO NOT Mount the wastegate so that the top diaphragm housing is less than 100mm from a heat source
- Allow for adequate cool airflow around the top diaphragm housing
In nsw the cops are lazy. My mate with a 33 god defected for the STD bov then he had to get a blueslip to pass so no matter what you do they will pick anything they can shiny or not. I got done for having a gear knob with no patten go figures. Thanks Simon32 yeah the cast seems to break in the perfect spot everytime then the cleaning part sucks. You could have the wastegate mounted under the turbo but boost spikes would be a issue
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
