splitter stays in the final product looks good and i cant see any problems with defects its alot better then having a turbo reaching for the sky and saying ill take a red one officer. on my set up i had no problems with boost control after my MBC was removed i was using a small gate to 35mm. the 44mm will have no problems controlling things. i think the external gate on the manifold will help the mani flow so much more then without. iv had 260kw though a 38 pipe a 44 could flow over 300+ im guessing
yeah i know il correct myself 200 depending on turbo. it comes down to personal preferance i like it on the manifold as i can put a diferent turbo on if i blow one with the housing your restricted to what turbo can be used. im going to be putting a gt3040 on one of these manifolds and there is no way im welding to one of those housings
External gate is VERY hard to keep hidden. Even custom jobs that I have seen where the intention was to hide the gate, it's still easily spotted if the cops are looking around. if you're worried about cops at all, I wouldn't be going external gate.
I'm not worried about them at all hanaldo I'm just trying to keep it away from first thing to be seen if you know what I mean
And keeping it easy for turbo change if need be for pits
Edited by luvpsi
That's it alot of the time if something catches there eye they will defect you most if the time they don't get there heads in the engine bay just look for something sticking out they are like crows shining things get there attention
I was trying for stealth too with my setup, thats why I avoided external gate for a while, but the boost control is awesome it sounds great.
I have heard both good and bad stories about welding on the manifold, but as of yet I have never heard any issues with welding on the housing of the turbo - provided it is in the correct spot for flow, there is a diagram somewhere about it.
I got mine heat sprayed aswell for stealth+ cooling ( for cooling it was a waste of time, cant remember all up but I think was about 400 for manifold and turbo housing and had to send it away for a week ) but I think the matt balck does help instead of a bright colour.
Decided to make a aluminium heatshield aswell to cover the external gate - which 1. worked way better for hiding things 2. actually functioned as a great heat barrier.
Maybe you could do something like that? Sure, a cop if they were keen could see something, but with the intake pipe ontop and other crap its very hard to tell and just looks like a heat shield... if they are that keen they will get you either way.....
This was while I was finishing drilling the holes for it:
Quoted from the Turbosmart installation manual:
- DO NOT wrap the body of the wastegate with exhaust wrap
- DO NOT Mount the wastegate so that the top diaphragm housing is less than 100mm from a heat source
- Allow for adequate cool airflow around the top diaphragm housing
In nsw the cops are lazy. My mate with a 33 god defected for the STD bov then he had to get a blueslip to pass so no matter what you do they will pick anything they can shiny or not. I got done for having a gear knob with no patten go figures. Thanks Simon32 yeah the cast seems to break in the perfect spot everytime then the cleaning part sucks. You could have the wastegate mounted under the turbo but boost spikes would be a issue
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
    • Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter My OEM NC1 CAI pipe: From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL   Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air  As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now The aftermarket "performance" CAI elephant in the room: Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA Like dis:
    • Nice one, I'd argue that the white S1 RS260 is certainly the best looking of the Stageas. And yes, fully agree on the forum situation. It's a bit of a shame, but at least SAU is a good place to be. I found the facebook groups to give me FOMO because people were trying to one-up each other and show off in some way. Feels much more natural here. There are people with seriously nice builds, but I can appreciate it rather than it making me question my life choices. Might be that people are more open with sharing how much work/money/suffering it takes to actually get there.
    • Evening, wanted to pop in and finally register to say hi to everyone here on SAU!   It's been a while since I've been active on a forum, but back in the day I used to be relatively active on ClubLexus and other hobby-related forums. I'm glad to see SAU is still around, since with the advent of Facebook and Discord it seems forums aren't what they once were. As a recent new owner of an S1 260RS Stagea, I've found so many older guides and helpful tips from SAU that I figured I needed to join and say a grave thank you. My recent acquisition has only become legal in the US for the past year, and knowing that similar car enthusiasts from across the pond have already figured out the kinks and tricks to get these 25+ year old cars running well. I look forward to diving into more of the SAU forums as well as hopefully contribute some info myself for future posterity.   As a pic tax, here is one of the few good photos I have of my Stagea. I hope to get way more in the future!
