splitter stays in the final product looks good and i cant see any problems with defects its alot better then having a turbo reaching for the sky and saying ill take a red one officer. on my set up i had no problems with boost control after my MBC was removed i was using a small gate to 35mm. the 44mm will have no problems controlling things. i think the external gate on the manifold will help the mani flow so much more then without. iv had 260kw though a 38 pipe a 44 could flow over 300+ im guessing
yeah i know il correct myself 200 depending on turbo. it comes down to personal preferance i like it on the manifold as i can put a diferent turbo on if i blow one with the housing your restricted to what turbo can be used. im going to be putting a gt3040 on one of these manifolds and there is no way im welding to one of those housings
External gate is VERY hard to keep hidden. Even custom jobs that I have seen where the intention was to hide the gate, it's still easily spotted if the cops are looking around. if you're worried about cops at all, I wouldn't be going external gate.
I'm not worried about them at all hanaldo I'm just trying to keep it away from first thing to be seen if you know what I mean
And keeping it easy for turbo change if need be for pits
Edited by luvpsi
That's it alot of the time if something catches there eye they will defect you most if the time they don't get there heads in the engine bay just look for something sticking out they are like crows shining things get there attention
I was trying for stealth too with my setup, thats why I avoided external gate for a while, but the boost control is awesome it sounds great.
I have heard both good and bad stories about welding on the manifold, but as of yet I have never heard any issues with welding on the housing of the turbo - provided it is in the correct spot for flow, there is a diagram somewhere about it.
I got mine heat sprayed aswell for stealth+ cooling ( for cooling it was a waste of time, cant remember all up but I think was about 400 for manifold and turbo housing and had to send it away for a week ) but I think the matt balck does help instead of a bright colour.
Decided to make a aluminium heatshield aswell to cover the external gate - which 1. worked way better for hiding things 2. actually functioned as a great heat barrier.
Maybe you could do something like that? Sure, a cop if they were keen could see something, but with the intake pipe ontop and other crap its very hard to tell and just looks like a heat shield... if they are that keen they will get you either way.....
This was while I was finishing drilling the holes for it:
Quoted from the Turbosmart installation manual:
- DO NOT wrap the body of the wastegate with exhaust wrap
- DO NOT Mount the wastegate so that the top diaphragm housing is less than 100mm from a heat source
- Allow for adequate cool airflow around the top diaphragm housing
In nsw the cops are lazy. My mate with a 33 god defected for the STD bov then he had to get a blueslip to pass so no matter what you do they will pick anything they can shiny or not. I got done for having a gear knob with no patten go figures. Thanks Simon32 yeah the cast seems to break in the perfect spot everytime then the cleaning part sucks. You could have the wastegate mounted under the turbo but boost spikes would be a issue
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
