What flange is on your greddy manifold? If its T4 then no.
T3 or 3 bolt then yes.
T67 10cm would be nice on the 2.8, be sure of how much power ur chasing then pick the turbo to suit. Dont concern yourself with picking one to suit your manifold, it doesnt work like that.
+1 a T67 on a 2.8 would be sweet! I would copy SimonR32's setup as much as possible with the 6boost manifold and the Tial MVR 44mm wastegate. Same power with more response would be spaz!
I'm looking for a replacement for my S2 RB25, I've read through this thread but couldnt find a concrete answer, the range of Kandos seems to be a bit tricky. Would something like this (TD06SL2-20g) http://www.ebay.com.au/itm/Kinugawa-Turbocharger-RB20DET-RB25DET-2-4-Cover-8cm-T3-V-Band-TD06SL2-20G-/290649134040?pt=AU_Car_Parts_Accessories&hash=item43ac09d3d8#ht_2643wt_922 be ok for a mild setup on my 25? I want an internal gate that will fit on the standard exhaust manifold. Looking for around 250-270rwkw. Would it be alright or am I way off?
I've got a FMIC and exhaust currently but I've got a z32 AFM, injectors, PFC and upgraded in tank pump waiting to be fitted.
Yeah how so? Are they struggling at higher boost levels? I'd be interested to find out. I really want to keep the engine bay looking standard. Id be prepared to sacrifice a little bit of power if it meant keeping an internal gate turbo on the stock manifold. But then again if it's going to be really shit I could just get an external gated one and just try to make it look neat.
Is there anything wrong with the 3" anti surge inlet covers?
Reason I ask is I'm look at getting Eiji to make me a TD05-18G with 10cm (its for an rb20) exhaust housing. And the options are either 2.4" normal cover or the 3" anti-surge. Any negatives for the anti-surge cover or reason to avoid? It'll be internally gated as well against the advice of everyone here.
Interested to see how you go with the TD05-18G. I finally scored an 8cm Trust TD05 housing so will grab a Kando TD05 core with 3" Compressor cover. Will throw it on my external gate / 6boost setup whilst my TD06-20G is being rebuilt. Will be interested to see how the setups measure up.
I need to order either of these by the end of the week. Thoughts? Going on an internally std RB20 with 6boost, Turbsomart 45mm gate, Plazmaman plenum and an 8cm housing.
Anti-Surge Cover
Or
3" Cover
The anti-surge compressor turbo has a slightly different turbine. 11 blade Inconel Wheel
The plain 3" cover is dimensionally similar but 12 blade. I think I will go the 12 blade plain comp cover unless some turbo guru tells me otherwise. Is the 11 blade wheel the TD05 version of the L2 TD06 wheel?
Ur brave to go internally gated dude, despite what everyone says- hope it works for u, if it does pple will follow suit, including myself!
Same same, I wana keep it internal too, but i think u can keep the stock manifold if u dont go bigger than TD06SL2-20G 10cm housing.. Which is kinda where im headed, till someone proves that the internal gate works too.. Dont know what the prob is, moreso issues with holding boost n boost creep as u say
If you guys have to have an internally gated turbo then why not go with a proven hypergear??
Exactly.
I really don't understand why people are fussing around with the internally gated Kando turbos when their results aren't great compared to the Hypergears which are working really well IG.
After reading both threads the Kandos SEEM to produce more brutal neck snapping acceleration factor on the street, less issues getting there and seem to love boost and have lot more potential in them, maybe this also has to do with the setups being external gated.. AND theyre half the price of HG turbos (kinda adds up to same with ext gate, custom dump, plumbing etc), but then later down the track u canalways swap a newer better kando turbo cos its cheap!
The internally gated TD05-18G 10cm is also available in a Trust kit. Having been passenger in an R32 GTST with one of these and comparing it to my TD06 they are more than enough for the street and deliver a noticeably smoother delivery. But on a 20 still fairly lethal enough to put a smile on your face. The TD05/TD06 really comes alive at 1.2-1.4 bar so screw the boost in I say.
TLDR; nothing wrong with the internally gated TD05-18G 10cm. TD06-20G, id be looking at least at a 45mm external gate (going off the trust kit;s specs)
wtf?????
Go check out the kando thread on Nissansilvia, few guys have tried the internal stuff with very average results...
    • Have you tried another indicator stalk? Sometimes these go bad and cause issues.
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
