in the exact post you replied to he said they are both 99 ron lol
Tony de you would probably find that the 5% ethanol wouldnt be that great... while ethanol has good ping resistance it is only seen in high quantities thus far, and it will probably be more consistent for u to run straight 99 as the ethanol will result in a leaner burn.
The E5 is also more likely to be a lower grade fuel and the RON bump is from the ethanol, again probably a mask in this case.
I would like to see atleast an E10 variant added to regular PUMP (98 RON in OZ case). Price would stay about the same but we could pick up some ping resistance and have a better RON rating.
so if i want 300rwkw out of a rb25
what would be better one of this kando turbos
or a garrett gt3076r 56t with 44mm external gate
both on a low mount without cams but all supporting mods
with bp98 fuel
Edited by jet2nv
ive had a read through it but theres over 100 pages from what ive seen i think im gonna go a 3076 just wanted some peoples opinions
Peoples opinion on what? a gt 3076 (which one??) or kando? or vs a kando? or vs a NA civic?
be more descriptive mang
Edited by Rolls
if you read the previous 2 post you would see what im asking i know theres different types of kando and 3076 but i want to know which oneis better for my stated power goal
For 300kw you will need a T67 from kando or the 3076.
The 3076 is likely to be 'more responsive', but once on full song it appears the T67 walks away and ends up with more power.
As a rule of thumb on 98 you should expect 280-300 from the 3076 or 300-330 from the T67 on roughly 20psi each. If you are planning to go external gate you should probably just take the T67 as they are freaking cheap but if u want internal you must get a 3076.
You can also look at a hypergear G3 (much cheaper than both of the above and is also a solid performer - close to 3076 numbers a little laggier).
yeah im extremely familar with stao and his turbos ive know him since he first started and tried ALOT of his different turbos yes they make good power reliable cheap but im more concerned about resale and response the turbo from stao which is very close to the gt3076r is pretty much the same price i get the gt3076 for i already have a dump pipe braided lines and everything ready for the garrett
so yeah i could sell it all and try but after trying a g3 and a gt3071 and the 3071 making 280 and super responsive i think the 3076 is the smarter way to go unless someone here has tried all 3 maybe lol as most motors/dynos are different
I dunno but the HG SS2 also looks to be in GT3076R territory, just my opinion..
A TD06H-25G is bigger than a T67. I may be going one of these on my Rb30. Just trying to decide on what config I will go. IE 10 or 12cm turbine housing, TD06 or TD07 compressor housing, Port shrouded or unshroaded and cast or billet compressor wheel.
any 1 wanna put there POV forward?
Edited by urtwhistle
12cm for Rb30....
cheers
darren
how laggy would a gt3582 with a anti-surge a/r70 wuth a .63 rear be compared to a gt3076r .82 if my goal is only 300-310rwkw max
welcome to the kando dynamic thread, where we talk about kando dynamic turbos.
Please ask a question about a kando product or go to the Garrett thread. There are a number of threads dedicated to gt30 based turbos where your question would be entirely relevant.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
