:cheers:
FAAAAARRRK THAT MAN...thats freakin awesome, I thought you might struggle to make 270rwkw, man that is a killer result! ! There is no way I'm going a HG or Garret now, it does hammer on the road right?? ! ! ! Big kudos to you guys man.........:cheers: :cheers:
PS - thats with a screamer not plumbed back hey - bit worried there..
yeap, with the screamer vented, and it hammers on the road, so awesome to drive.
with it plumbed up, it made 260rwkw~ @ 17psi[still better results then a HG SS1PU ;) and boost comes on earlier ]
I'm only against screamers for legality reasons but if it gets you an extra 20-30rwkw then.....:wacko: ??? Just wondering why don't you extend the screamer and 'hide' it behind the exhaust pipe so when the popo open the bonnet they will not know its not plumbed back apart from the sound..?
Its normally when they hear the screamer that u worry
Weak :)
Nice results Dori34, I saw something was mentioned about VCT, was it not working?
cheers mate, yeah we connected it up at the solonoid (cause my old tuner d/c it as he heard a light tapping sound internally when vct was activated) but we couldn't find out why last night it wasn't working, so that will be saved for another day when there is more time.
It is a good result, but 280 @ 17-18psi is what we always expected..
Bit worried about the high end surge though.
think I have acquired an npc farbotic clutch and flywheel on the cheap...woop woop. :banana:
to be honest, i was expecting 280~ at 21psi (no higher)
and i made it with less boost, so im cheering.
npc, good choice, get it fitted and back on the dyno asap!
Better, based on what? The SS1PU still has a stronger midrange despite your boost coming on earlier and you running a screamer pipe, look at where the power comes on and how much of it. When you compare the graphs, it reveals something similar to my prediction of the drag race between Artz and I. Be interesting to see what happens when you get VCT sorted though, it may fix that little "trough" you have in the middle of the graph and give you a stronger midrange to overtake the SS1PU. Though, it would also be interesting to see what happens if Kasko can get his SS1PU to hold 20psi up top. Either way, congrats on the results, can't argue with a good top end and you sound happy with your purchase. Also congrats to JEZ who seems to be the man to go to in NSW :thumbsup:
Really, I was expecting closer to 300 by then. .:D
I think if we can match Mick-o GTX results or even get close, we're winning..
Its a big ask of the little kando but..
Dori once you get your VCT and surge sorted, I would like to see you get it dyno'd at unigroup.
unigroup graphs always seem to have so much area under the curve, but im not sure if thats scaling or actual results..
ive asked mick_o to do the same and come to jez, would be interesting to see..
Im confident you guy will catch the GTX on eflex, his results were similar on 98.
u might match, i probably won't lol
when is this drag race happening that you speak of Birds?
VCT will definitely fix the lil trough betwen 100-110km
When I get my frikken car back :/
Have to get it out of the way soonish because I'll be switching to E-flex after a month or so of driving on 98. Time to see what an ethanol powered SS1PU can do :thumbsup:
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
