Very very nice result - getting VCT working might actually help with the surge too.
That's what I was thinking..
My understanding of compressor surge is that the turbo is pushing more air than the engine can actually ingest at that point in time..
So getting VCT working, which will increase the engines breathability in the low-mid rpm range may be enough to get rid of the surge.
on the same note opening up the WG pipe might expel extra has yeah..its a 44mm gate isn't it dori
into what size pipe
here's a nice one of the manifold/wastegate pipe glowing
but i put up proper pics a few pages back, go back & look for it, would've been around Jan-Feb sometime.
ahhh..i see the problem,,somebody left a penis in your engine bay man
I will let u know this week methz. Ill tune my drifter. Only do a run or two on 25psi then back down to 20psi
sounds good mate, be interesting to see the result
Id love to find a turbo that is all in by 4k and revs to 7500 hard
gt3582 is nothing nothing then all in at 5 and im not really into it much anymore.
3rd wheel spin at 120 is fun though haha.
let us know how u go!
into what size pipe
:laugh:
I was looking at going the way dori34 has and while the sceptisim I came across scared me away, I'm impressed! What are the thoughts on the limits that sort of setup would have?
dori34, how much clearance have you got to the tower and engine mount?
So. Hopping to have my setup tuned within next 3 weeks
25 neo
Stg 2 tomei pon cams
880 cc Denso on gen Greddy rail
Gen Greddy manifold
Sard fuel reg
Spitfires
Nz hi mount if ever turns up
44mm tial gate
3.5 straight through
Greddy cooler core 90mm cold 2.5" hot
T67 25g 10cm
Will post results ounce tuned
mine only seems to serge if you load it up in too high of a gear for the rpm ( say WOT from 2.5k in 3rd or 4th gear) . It also did it whilst tuning down low as the runs are done in 4th. Never surges on the road boosting through the gears (should say spinning through the gears lol), unless you do it on purpose. So just a touch up tune with vct enabled will probably eliminate the problem. Anti surge sound tough tho. I love this turbo set up, best fun iv had in a car, comes on bloody hard. Very nice results for 98
wtf our bays look almost identical dori, down to the way ive cut the standard heatsheilds, the matt black charge pipe and intake. only exception is for your gate pipe angle and coil pack colour. fwark even my user name is the same as urs.
how many of you lost significant power over 20rwkw by going plumb back like dori34? Anyone else running screamer?
who you baracking for now hypergears going Kando Rondo?..lol
cheers
darren
Actually , I'd like to see a td06 bolted on the hypergear test car , just for a comparo between the two . I'm pretty much subscribed to the two threads in here waiting to see an outcome and weather stao actually can improve the td06 in any way
:laugh:
There is heaps of room if your interested send me a pm
My latest run, I doubt there is much power lost with my external plumbed back in, the GTX must be well out of puff by now.
It would depend entirely on the exhausts ability flow at the end of the day.
cheers
darren
Kando for me dude, and Scotty, you have such a nice meaty curve on your graph - lots of power - thats the GTX3071 on E85 right?
Yeh mate, just the baby GTX on the stock crossover manifold and Eflex. Not bad for an unopened VQ don't you think? :whistling:
I just wish I had the coin to slot a VQ25det in a light car, rx7 or 1600 perhaps? One day...
Here is the boost graph from above.
200kph was just over 6k I think in 4th gear, 6500 perhaps? Dyno wont go over that speed. Can you work it out from there?
The boost ramps slower now as I re-routed the wastegate hoses, boost was spiking with boost pressure to the top of the gate though. It still makes full boost by around 4k with the 1.06 Tial rear.
I probably should have posted in Micks GTX3071 thread but I was answering the wastegate plumb back question.
Maybe the Chinese will now introduce a Kando copy - 'Can-do Turbos'. Made in China and me can do!
He's importing parts out of Taiwan then assemble and balance them here of some sort. now with billet wheel and probably ceramic roller bearing soon. lol. be pretty keen to see what he can do in modifing them into a stockie bolton.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
