Do we have any results here from this turbo? http://www.ebay.com....#ht_2463wt_1139
Same wheels and covers as all the T67-25g results... Only difference being the anti-surge cover (which may or may not make any difference) and the size of the shaft which should make no difference.
Ratio works as follows as we work back from the large engine will small turbo scenario.
48psi in exh manifold and only 10psi in inlet manifold works out to a ratio of 4.8:1 in theory if we were to try and get the same 48psi of back pressure in the exhaust manifold on the 2l we would need to have 32psi on the intake based on the 1.5:1 ratio (derived from testing).
ahh ok now I get ya, I was reading it wrong.. :thumbsup:
thats not what she said :P
I don't think it will make anymore power than it did before..
Possibly spool a little earlier and feel better/faster through the midrange though.How's your compression, holding up alright, have u gone new valve springs as well as cams?
Lies 600hp or bust! :yes:
If it went another 10-20hp up top and 20-30 through midrange I'll be happy... Hoping that 20psi will be similar to my old high boost without cams.
No valve springs, mine have been fine up till now.
Compression tests are for nancies :whistling:
Edited by SimonR32
I went to run cams without the valve springs but a few people scared me out of it without horror stories :/
Mine were fitted up this week with the springs and will be tuned possibly Monday, Good luck with yours!!! Hope the cams do make that sort of improvement!!!
The kando should be similar to 3076 yeah? I think thats what i read in your thread?
566hp at 1.7 bar (422kw) without correction
515hp at 1.3 bar (384kw) without correction
So it made an extra 40hp and we didn't even push it as hard, comes on about 350rpm sooner as well. I'll post up graphs tomorrow at work :)
also 590hp at 1.7 bar (440kw) with correction LOL
Edited by SimonR32
Woah!!! :O
Congrats on the results! Amazing!!!
love how this man thinks! nice power dude, 140mph here u come!
For those who mentioned getting poncams, i used a guy in the US that delivered a set for my NEO for about $625 or something..... So they are certainly great value for money based on the results above..... Not sure what they sell for locally but if anyone wants the details i can go find them :D
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
