His comparison overlay was his low boost run
why not overlay your high boost run simon? dont want to be unfair lol
i wonder how the 3076 would go with more boost also, hmm.
More power, naturally - they certainly won't be choking at 17psi on an RB25 like that. Makes the comparison a bit difficult that the octane rating and boost level are slightly out, but I still feel the likely overall result all things being equal is the GT3076R will come on earlier, and fall over a little earlier earlier (as my opinion has been the whole time) and that looks credible from that comparison.
I dont necessarily believe that it would make more power, but it should in theory.
The fact is you could max the turbo at the same power level but at two different boost thresholds on two different motors. That being said its not out of the question that the unit is out of flow at 17psi, but logic suggests it has more in it (17 is a pretty low number on an RB25).
If it were an RB30 for example I wouldnt be surprised if it was hitting the power target with no more available flow at that low a PR.
All that being said I'd love to see the whick turned up, for science of course.
I think mine made 475hp on gate pressure (1.1bar) so not too much shy of the 488hp that 3076R made on similar boost. I think the 3076R also had more boost in the mid range but tailed off top end!
I'll try and get a print out of boost vs power for both the runs when I get a chance
No idea why you think you need to tell me this.
I think it is more or less out of the question that it would be out of flow at 17psi on a mild RB25, tbh.
Because you and I are not the only two reading/going to read this thread.
Sometimes you need to state the obvious so that people dont assume that a 3076R has HEAPS more left in it at 17psi, coz it simply might not.
I know you are the turbo overlord, that's why I theorize with you whenever possible and ask you first before I go out on a limb with a whacky idea. Stop thinking im condescending you when im not.
Ok got you, fair enough - sorry took that wrong, and agree.
I would love to see both the T67 and GT3076R taken to "all in" levels, or was the T67 maxed out in this instance?
And why was the GT3076R taken to "only" 17psi? I'm guessing that it didn't max out there...
you should be fine bro, that housing is an actual TD07 MHI spec item the housing Jez and Dori are having issues with is a 'drilled' TD06 3" cover. The Trust style one that never came with drill holes in it normally lol its a shame it didnt work though :(
Ahhhh cheers that makes sense. Well I guess we will have to wait and see what happens when it gets tuned next Tuesday. It will be very interesting to overlay with Simon's results as it will be the same tuner, same dyno but with a durty 30 spooling it
Oh yeah, in other news I did some road tuning this weekend on a GT4 Sillycar running a built 3SGTE (268deg cams) and a GReddy TD06-20G - was making 1bar around 4300rpm from what I could tell and had a fairly solid pull to it even on the road tune... at least compared to other GT4s I've been in. I expect to get it on the dyno in the next few weeks, and we're going to go up to 25psi for the glory tune (won't be typically used at that boost level). Tuning it on a hub dyno, any guesses on what we might expect?
Understeer!
A 3 inch cover on a dirty 30 with td06h...me no think so :no:
Think you might have a cooker on your hands, that's if it doesn't choke, but I am often wrong so good luck with it
only 1 way to find out. it won't be hard to change the housing to a 4" if that is the case.
Its a proper TD07S 3" anti surge housing ARTZ... specifically designed for a 25G wheel, off a big truck of some sort.
Im pretty confident it will work well.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
