heres my entry form, just qualifies :laugh:
RED..pulp @ 15psi (E85 @ 15psi made 288kw)
BLUE...17.5 psi on E85
GREEN..21.5 psi on E85
As you can see the extra psi stopped making enough difference to be worthwhile. 18psi is about where I wanted to be anyway so its worked out good..
The torque increase through the midrange on E85 is brilliant, makes it so much more driveable in regular traffic situations..and after 20min or so driving around I opened the bonnet to find a very cool motor..
Anyway its no T67 but it is very nice and responsive to drive, with more than enough power to get me into trouble..
Should keep me satisfied for a while.. :) good diff and tyres on the want list now..
What turbo is that
What turbo is that? looks almost identical to my graph.
Realistically it doesnt matter if u get the 3" or the 2.4"...... But if u go the 2.4" ull be able to use the stock intake pipe for teh epic stealth ;) just need to make a heatshield to cover the gate.
If I had an RB20 powered car I would probably do the exact setup we are talking about. Stock manifolds, TD05H 18G with a gate off the housing. Stealthed up and stock position. Like I said 230-240kw and it would be pretty responsive/solid. Ive recently done a TD05H 18G SR20DE and that is a weapon. Faster than a 260rwkw 3076R SR20DET (both S13s).
can u fit the td05 in the stock turbo position?
and ive got one of those china split dump screamers (havnt used it yet) could i just run an internal gate td05 with this so i dont even need a wastegate?
well I dropped mine off for tuning today. Bit of let down really but nothing super bad. Turns out my AFM is too close to the turbo and is causing it to be a pain the ass. The real issue was that it was spiking uncontrollably. ASG told me to change how the waste gate merges with the collector on the manifold. Does any 1 have any input on how it should be changed. The manifold is 1 of the NZ steel 1's from the other thread. and the gate is a Compgate 40.
Chris
I'm running stock cam gears still and stock airbox..that could be worth couple hundred rpm lag..either way it is what is and should keep me content for a while..If I get bored a simple 25g + manifold conversion could net me 100kw extra.But for now, she'll be right..
LOL, for what its worth i run a dirty old HKS filter in my engine bay with no shielding just a duct to it :whistling: I am going back to std airbox so I hope it isnt going to hurt power
Yeh, I am betting its the length of pipe before the manifold. Some people have problems with the 6boost having boost creep when they plumb the gate down near the steering rack rather than high up near the collector. Thats the reason I got rid of my Trust Type R gate as it was too large to package near the collector.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
