It also stops if I turn the car off turn turn it back on again..Aside from turbo and cooler whole setup is stock standard..Actually just thinking, I did pull the restrictor out of my boost gauge line, this couldn't do it could it
Will do :cheers:
I know he spent a bit of time sorting the cold start so what are the chances it would be fine without the AAC anyway.. I always warm it up before I drive, I don't have aircon and I'm sure there is enough power to run the PS.. So what is it good for really ?
Will do :cheers:
PS does put a lot of load on the engine though, mine used to stall with the NIStune when I turned the wheel at idle.
But the PS switch should allow for that, pretty sure i swapped a few back in my Falcadore mechanics days..... Assume skylines would be similar?
Yeh, but if you didn't have the IAC valve, how would the ECU raise the idle?
I usually try to avoid turning wheel at idle anyway, on any car..drive an old car with np PS and you learn pretty quick to only turn the wheel when car is in motion ;)
Yeh I try to do the same, but to get my front bumper off I have to turn the wheels. I just think it's rather inconvenient NOT being able to, even if I usually avoid it.
just wondering..ive never seen the td05 come in 25g, i was going to go for a 18g but would i see any benefits with the 25g on the rb20?
maybe holds boost longer? longer spool time? so on
http://www.ebay.com.au/itm/Turbo-Turbocharger-Hybrid-TD05H-25G-AR60-8cm-T3-Turbine-V-Band-4-inch-Cover-/110859057273?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19cfb6f879#ht_2063wt_855
Edited by RBert
TD05H 25G is not something you should go for. The 25G wheel can flow upward of 500HP, the TD05H wheel is stretched at best to be nearing 400HP.
Even a TD05H 20G is a touch of a mismatch, and can often run into surge issues.
FYI the different between an 18G and a 20G is the inducer size. Sort of like comparing a 3076R in 52 trim and 56 trim. Going the smaller will trade a little bit of top end for some spool. In this case both wheels have a 68mm OD but the 18G is a better overall match to the TD05H.
The best way to get a grasp of whats a good combo or not is what Trust have developed and sold as their own kits. In this case either pick the TD05H 18G or the TD06SL2 20G...... One for better low end and midrange, the other for higher end power and midrange. 240 and 260kw respectively.
okay thanks for that, back to the td05 18g then, but is there a way around the drop in power higher in the rev range?
also if i go td06 for more power how much do people usually loose low down as in spool time so on?
So I was just browsing kandos on ebay again and noticed that all TD06sl2 t3 10cm turbos come with anti surge covers now...
Whats going on there??
I haven't noticed any surge issues apart form the huge surge of power when i put the foot down :P
haha tama easier said than done :P having 350 with the td06 is all well and good but i don't want to wait an extra 500-1000rpm for it. td05 for the street and a few track days will make me more than happy.
You wont feel it losing power up top mate. It will haul to redline.
Only difference is how much of the peak power is made and how much spool time is lost.
The TD05 is likely to be quite lively between 3 and 4k RPM with a little more meat than the TD06 from 2 - 3 aswell. The TD06 will probably be very flat from 2 - 3 and get a fairly abrupt rush of power around the 4k mark. Like I said, TD05 will probably go 240kw and TD06 will probably go 260.
This is all provided you set it up right.
I found by applying the KISS theory these were the results I got
Rb20
drifting or hard track = tdo6-20g
street with occasional track = td05-18g
Rb25
drifting or hard track = t67-25g
Street with occasional track = td06-20g
Now there is no doubt other options outside of this but quite frankly, if you can't figure them out by yourself, well your probably punching above your weight... Anyway so what's the verdict on the SL2 fellas..seems it shapes ok to an old HG or a 3071..but is it any better or worse, cause all in all the setup is almost as expensive..
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
