It wasnt known till last week. Too many variables still.
I pitty tuners! Especially you :) It seems so many cars get given to you and they are just loads of problems and so hard to get right :( Will be interesting to see if you can get results that give a clear indication of whether the anti surge housings hurt performance at all.
My kando t67 antisurge has drilled holses and a machined slot, i see no reason why this would work any different to HKS/turbonetics style antisurge?
Did DORIs home brew anti surge just have holes or did it have a connecting slot to the front of the compressor also?
LOL yeah i got the Ryobi drill out and went to town with the housing
Hey I'm new to sau been on ns for years
Well ok my set up
Rb20 in s13
Refreshed motor new rings bearing metal head gasket cleaned block
ATM it's running stock turbo and running gear
I want to go td05 18g for response
Have been told to run td06 20g but I don't need or want that much power
Has anyone running a td05 18 ex gate ?
The power I'm after is 220kw
I'm going to be running
550 injectors
Z32
Stock manifold with 38mm gate tail welded on
Niss tune
What kind of power should I get?
I want tge power and response for drift !
-Colin
For 220 and good response why not send the stock RB20 turbo to hypergear?
He could easily make you up a turbo to suit. Best of all, it would bolt back into place where your one is now.
I think he charges $960 for that service and the other parts should all be off the shelf. no external gate, no big costs etc.
I'll buy one if some monkey shows some half encouraging results haha
i'll be a monkey if somebody gives me money :D
wouldnt mind installing an EGT sensor which means turbo out, maybe Stao can do me a billet core for easy swaps..but yeah..no $$$$ atm...
td05 on an RB20 has been covered within the last 20 pages, you could read the thread that we all put a lot of effort into and do it some justice...
advice still stands @ 220 = highflow. highflow is still a brand new turbo, just with your old housings. that way your brand new turbo bolts back into place where the old one was.
Now that I am actually making some progress and have some idea when this thing will be done, thought I should give an update on my build. Here is my setup:
Stock RB25 in an R32
Kando T67 10cm on a 6boost manifold
Tial 44mm external gate
Freddy Plenum
Bosch 1000cc injectors
Link G4 ECU running E85
Going to Scotty's next weekend for fabrication of the exhaust, intake and intercooler piping and have a tune booked with Trent at Chequered Tuning September 3rd.
Car has been off the road since SAU Nats last October, so to say I am excited would be an understatement.
Freddy Plenum
Cool, I will have another GTSt to play with :) Keen to see the result with the R32 gearing
Already have r33 diff ratios and putting a 25 box in as we speak after losing reverse on the way home from sau nats. so no 32 gearing
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
