Just email him instead, and ask for a discount while your at it!
email him your details and ask for a paypal invoice, just say can you please do this turbo for a discounted price because we are not using ebay? thanks.
he will reply with the invoice and probably 5% off
[email protected]
I contacted him on Facebook and he said non antisurge should be back in stock August
Well I can see a few non anti-surge models there and it IS currently August... that being said, nothing released on anything that I want atm haha
Edited by Reflector
Has anyone else had issues getting a response from Eiji (not sure this guy is really Japanese!) when there are problems? I ordered a turbo water and oil line kit from this guy and the oil line was missing. I have emailed him several times but he will not respond. I have been waiting about a week and a half now. Looking through his feedback it seems to be a common trend.
Ya i had issues- sent him coupla emails last week as I wanted to buy a TD06 but didnt hear from him at all so not buying the bloody thing haha. Going Garrett now, pay more for something thats well proven, but I still need to buy lines n gaskets from this Kandomaniac so bit worried there haha..
Havnt had any dramas of kando myself and to my knowledge several mates have had positive feedback,fair enuf one of them was sent wrong fittings but within 36 hours he had the right gear at his door...Id say he may be wery busy
ill be sending back the td06-20g 8cm internal gated turbo kit and swap it for the external gate version, any suggestions on the gate size? ill be running a rb25
rather than waste money on postage sending it back, just ask him for a discount on the external gate housing.
you will need a 10cm housing for the RB25, 8cm is 2L size.
From his facebook it looks like he came to Australia to world time attack so might explain delay in reply.
id like the set up for drift use, would that be the choice you reckon?
Did anyone ever get results from a modified L2 8cm with the billet wheels and BB core? (probably on a 20, but a 10cm on a 25 is also good)
I know Roy had one sitting around but I don't think it was ever tested.
Back to back on the same car would be interesting to see I think.
Edited by Wheezy
I sent him a message via ebay regarding a few products on thursday last week. I think there's only about an 1hr time difference between Japan and here so I assume he's either read and disregarded it OR, he hasn't been on for the last few days.
I'm actually considering contact KAMAK dynamics and getting a quote off them. Anyone dealt with them or just kando dynamics through ebay?
I'm pretty sure they won't sell to the public, need to go thru a reseller.
somebody mentioned eiji was down at wtac so he wouldn't have complete access to email or eBay.
patience lol
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
