Got mine tuned today. 380rwhp @ 17psi. We had problems all over the place getting it running, once those were sorted then had issues with trying to tune it with the ECU not playing the game with the TPS. The guys did an awesome job in the end and we called it a day as just run out of time.
So thats the T67 with antisurge, NZ manifold, Tial 44mm MVR, Stock inlet manifold/TB and 98 oct.
Will post a sheet when i get it, was in a rush to get home so forgot it. Haven't driven it yet, just got home as i live 3hrs from the tuners and she's still on the trailer.
thats good to hear the anti-surge worked for you, it was most probably just my car didn't like the Anti-Surge cover for some weird reason.
I know a few evo's & sti's run the anti-surge cover without any hiccups as well.
Did you try a higher boost setting or didn't have time to go past 17?
Yeah just run out of time, held the poor tuner back late as it was :(
It seems to have, still yet to drive it to gauge response etc.
hahhaha yeah I ment the Patrol, I wasn't paying attention when I left my work at the other end of the street and nearly drove into it lol. I'm real bright some arvo's hahahah
Dont worry, when ive finished a night shift and i drive the 5k's home i could easily run into something then just fall asleep.
Was yours a T67 as well?
Took it for a quick spin yesterday, has some oil leaks from the oil cooler blocks. Pretty laggy, gate doesn't open till over 4k, then just pulls hard to the limiter if ur not quick, the sound so far is cool, I think because it's laggy it won't horn me for a while. When it goes back for more fine tuning we'll see if we can get it on earlier.
so after a few hours of reading and not finding the answers i was after,does anyone have results of the tdo6 20g sl2 on a rb25 with external gate low mount on pump gas?i would love to see sum dyno results if possible.cheers
no worrys jez will do.its definatly the way im gunna go just seems to be alot of talk about the t67 and how well it performs.i might need to do sum more reading to find sum more info on the td06. :unsure:
231 pages...so much crap talk in the thread yes, but guessing the question has been asked and answered every 5 pages means its been asked and answered over 50 times. ie, Kando dont do any such turbo. Go look at high flows from whoever you fancy for hiflows
What kando turbo can people reccomend for my r33. Im after an intenally gated with 6 bolt dump to chase around 250ish rwkw.
Also prices would be handy. Thanks
kando need aftermarket manifold, external gate, dump pipe and etc. For bolton turbos look into hypergear's turbo thread.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
