Swapped my rear housing to a 10cm, made 235kw on 18psi. Was expecting more, and the Stagea needs more being a big heavy car.
Mick had to put a shim in the turbosmart gate to stiffen the spring, as it didn't want to hold boost. You can see it peaks at 18-19psi and then tapers down rather quickly. Rubbish, my old tial off the skyline held boost rock solid.
Turbo didn't want to make any more power either apparently, which is pretty lame.
Specs:
Kando TD06H 10cm
Turbosmart comp gate (f**king rubish unit, never using it again!)
3 inch exhaust
return flow intercooler
high flow injectors
Haltech E11
Run in RWD
98 Octane
I guess I'll go a T67 next, or probably back to Garret. See what happens. Unless someone can suggest something good for 280-300kw? needs to be low mount though for uber stealth.
Adam I reckon its the return flow cooler. Those always cause havoc..
The turbo should make plenty more than that, especially with the H rear side. I'm assuming its a 20G compressor? 260+ should be more like it.
The fact the tuner thinks the turbo is running out of puff definitely tells me the restriction is in the intake side.
After seen Roy mentioning about the TD06H I went through all TD06H dyno readings on Trent's dyno and did comparison against the SL2 turbine. TD06H turbine appeared to be laggier without making any more power. You can try our billet SS2 comped SL2s that is a step up from the standard 20Gs, or I think a standard highflowed turbo would make more power.
depending on where the external gate is attached. won't make good results if it is welded on turbine housing, locating it to exhaust manifold would prove other wise.
Cheap return flow cooler do have heatsoaking issue and takes much longer to heat sink compare to a good branded cooler.
^^ This, if done right.
All Stao's attempts have been at 90 degrees to the flow I think, mine (Artz's) had a nicely die ground entry knife edge with a curved pipe. There is no way the exhaust flow can do a 90 degree bend while travelling at the speed of sound...
My thoughts exactly regarding what it "should" make. Interesting idea on the return flow cooler setup.
I like how the engine bay looks nearly stock (except the gate off the manifold). But if going the conventional intercooler setup to gain a extra 30-40kw then I'd be down for that.
Though pin-pointing whether it is the cooler setup holding it back, or if I just got a odd turbo or whatever, will be the tricky part.
Just don't buy a "conventional" setup the same as you sold me...what a piece of shit..i fixed it, but what a piece of shit...lol
intercooler pipes didn't line up, not enough silicon, the intecooler pipe mount that goes at top of rockers was complety wrong..lol
cheers
darren
Edited by jet_r31
I'm not using a justjap kit, we made our own using a core with inlet/outlet on the one side.
But still, kinda don't want to spend any more money on it until I know for certian, this whole kando ordeal I've had ... I probably could of bought a 3076 or something with the cash wasted :(
I'll do some digging on the return flow cooler problems though while I'm at it, anyone else had problems with return flow intercoolers?
cheers
darren
I sold you a intercooler kit? was it brand new? if so you might want to talk to Darren Spencer (as that's who I got it from) about it, he had been importing them and assured they'd be a good fit.
Edited by Run-It-Hard
yep, new, ..worst china cooler kit i have ever seen, f**king pos...if you paid a workshop to fit
it would cost a f**king fortune , absolute mongoloid...not angry at you, just telling you, if you go conventional..do NOT buy another one..lol
i just put a 38mm turbodumb gate on my hypergear G3 turbo of exhaust housing, straight 90 right at the flange, in a stagea has to be close as it ends up to near to the strut tower for my liking, and i am not really sure making it a nice entry makes any difference, i would want to see the results backed to back to worry about piss farting around with it(for this car anyway) . I also woudn't be suprised
if using different brands of gates made a big difference aswell
cheers
darren
Edited by jet_r31
My brothers car had the same problem low power reading cause the return flow cooler setup on his car
He went thru numerous turbo setups all came up short of what they should put out and got his cams dialed in still similar results
End up just changing the cooler to a normal cheap 3inch inlet opposite sides and bang 20kw should have done it to start
Unigroup told him to change the cooler at the start but he didn't want to butcher the battery tray as it was a 180sx they did all the usual tests pressure drop,exhaust back pressure and comp test all came up good
yep ^
I think its more so the harsh turn that the air has to do in order to flow back the way it came which causes friction to the air's particles and super heats the charge after its already been through the cooler.
You then have a nice cap on how much power you can actually make, and theres no way you can test it as pressure drops and air leaks have little to do with it. The core Adam is describing is the worst, where it basically hits a brick wall and is forced back the other way.
I know the air particles business sounds airy fairy star wars but thats actually the way it works. air gets friction against itself and gets hotter.
This is the kinda core I'm using lads. I get where your coming from Scott. I guess I need to decide whether I want the car to look stock and have average power, or put in a conventional cooler kit and gain the missing power I should have, if thats the problem.
Another thing Mick mentioned is that the turbo didn't want to make any more boost, maybe the intercooler is a restriction after all. I think I'll sort it out after Eastern creek next week.
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
