I was going to compare the 20G compressor with the 25G as well but I need a 10cm housing for my current TD06 to do that. I have a 10cm housing for my T67 and TD06-25G but not the 20G. I am curious to see the difference the bigger turbine makes to the power and response of the 25G compressor.
But fankly if I get to that point then its not a good sign as I dont want to be paying for that much tuning and messing with it then I am still not happy with any of them...then it gets very expensive
Yep, my manifold is 3 bolt.
Anyone run a 12cm housing with a T67 their RB25 or RB26? Looking at an equivalency chart the 12cm is meant to be 0.89AR vs the 10cm 0.73AR
Also, just discovered there is a 12 blade 65mm TD06 and an 11 blade 65mm TD06. Having just got off the phone with the US the 11blade 65mm TD06 flows more than the 61mm L2...hence why they prefer the 11blade 65mm turbine on the larger, higher flowing billet wheels.
LOL, who knows. Seems none of my 10cm housings match my old 20G or my new billet turbo so guess I will just grab a 12cm. At least I will get an idea of what the compressor will flow with the larger housing and will have to keep an eye out for a 3 bolt 10cm housing in the future.
So it seems the best we can tell is that the T67s off this particular GTR I was playing swapsies with were all 65mm turbines ...so will have to have a measure with some verniers over the weekend just to be sure.
LOL, the joys of using left over hand me down parts in a build.
I think I may just throw the T67 on ... I really want to try the billet wheel but perhaps I am best to grab a 12cm housing for the T67 and compare like for like with the 10cm I have for it. The Kando housings are only $150 so could be a goer if it continues to be all too hard...lol all i want to do is decide on a turbo then havea fire sale to get rid of one day-what if parts :)
It's a copy - I should have been more specific, do they have boost control issues with the internal wastegate setup? I am sure in essence the TD05-16G will offer the performance we'd be looking for if the boost does what we want it to.
I've done a TD05-18G on an SR from Kando, which works well. Has done a couple of tens of thousand K's since install and countless beatings.
Holds 16psi well with a minor tapper.
The TD05H-18G gives reasonable down low with a sudden surge onto good power at the 3700 mark. Motor is an SRDE non VCT. VCT models would do better in terms of spool character.
Very different.
The 18G is more like a better behaved GTRS/2871 than it is a 2530/2860RS.
the 2530 is more linear in delivery with less in the middle and up top of the curve. The 18G read over 500nm @4200rpm on a mustang dyno.
the 18g feels a lot like your half throttling and at 3700 you decide to pin it. The 2871 is similar but with less down low. The 2530 is probably boogying at 3300 and slowly rising from there.
Ok, i have only experience with the 2530, last one i did one million yrs ago did 228rwkw on a sr on 98, maxed out, picked up
2rwkw per psi so stopped at 18psi from memory, so on E85 would they do 250 ish?.
What peak numbers do the Td05 16G do on a Sr20 on 98 and E85?
I ask as my mate has a Datsun L18 in a fairlady , has custom efi mani, a diesel L series cast iron exhaust mani(they come with t25 flange
to), um ported head, camtech [email protected], 480 thou lift 116 LSA cam, and a AEM water/methanol injection setup ..we have these 2 turbo to choose from, (2530, and just looked, its a T517z)
now if i can recall, doesn't the 2530 spool a little bit quicker, and make just a little bit less top end?
cheers
darren
Edited by jet_r31
So it seems no matter what boost we squeeze into the 20G 310rwkws is all she wrote. So the lil TD06-20G has served me well for 10 years in April this year But this week she gets retired.
Whats the verdict on teh billet TD06s getting around. Have any proven they can outflow a 25G yet?
yeah but if 300kws is your goal...its beautiful...its only rated to 450hp anyway so its smashing that
being a DE on the factory dizzy, single coil and leads (20yo items lol) we left it on a very non agressive tune @ 16psi (14psi actuator). Does 210rwkw as is, a single degree more timing got a little noisier than Jez liked but was picking up roughly 10kw.
There was at least 230 in it on the Mustang dyno, but we werent in a position to get it there safely. The torque is there, so the car is fast regardless. it more or less has peak power at peak torque lol
to get an idea of a T517Z power potential just look at what a stock evo does. the 4G63 is probably better for making power but its also putting it to 4 wheels. a 517Z is a 16G6 compressor (ala evo 3 big 16G and evo 4-9).
Look at my comparison dyno graph of the gt2530 eflex vs tdo5h18g pump 98 shits over it below 4500rpm and keeps up just ahead till redline due to the eflex Same engine And mods just turbo and fuel difference
http://nissansilvia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=370325
I've got the tdo5h18g now on eflex aswell nothing special under 4000rpm but once above its aggressive as not very street friendly and only made 14kw more up top spewin I changed setup
went from 250kw and heaps of linear power before 4500rpm to 264kw but not much power before 4000rpm and the tdo5h18g is now on 24psi dropping to 21psi where as the hks2530 is on 21psi dropping to 19psi
Edited by hy_rpm
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
