Warranty is the biggest issue here having to pay $160 for postage and then another $160 if u don't want your turbo to be abandoned in case the workshop in Taiwan is closed then the most likely chance of paying a further $350 when they decide not to warrant the warranty. I think taos ss3 makes more power and response then these anyway and is in Australia. Well around around the corner for me, which makes everything everything that much easier and safer just a word of warning for anyone wanting to get one
Always worth updating the thread - interesting to hear, though strange it's contrary to years of use by people here! A mate had to return something along the line too, when they supplied an 18G instead of a 16G - and they sorted him out quickly... the customer service for folks I know overall hasn't been bad, did they give a reason as to why they didn't honour the warranty?
In some cases I would potentially take Hypergear more seriously as an option if I lived in Oz too, but in NZ Kando Dynamics makes more sense cost wise and in terms of knowing what you are going to get.
The comments seem to indicate that warranty has been honoured in each instance - correct?
Consumer having to wear the $160 shipping cost is not so good but if Kando have rebuilt/repaired at their cost I feel it's hard to have a gripe.
360 degree thrust bearings have been the way to upgrade turbo reliability since Adam was a boy - I seem to recall there is some sort of option along those lines available from Kinugawa?
Good good :) Occurred to me recently a lot of people seem to be getting failures over there and I was shocked to find "no BOV" was a trend in Oz. AFAIK (could be wrong?) thrust bearings get hammered when you get compressor surge, which would be massive without a BOV.
A lot of people getting failures? Or people getting a lot of failures? :ph34r:
  • Like 1
Heard of 2 people today having exactly the same problems with a td06. Seems like the first few batches at at the start where made perfectly then once his name got bigger the quality control has gone down hill. Happens a lot with a lot of big brand stuff
I get to work on them often, the shaft and bearing below came off a Kando T67 sent in last week, like I've mentioned earlier. This issue happens to T67 or those larger billet L2 based cores working with Rb25det engines on high boost. When compressor out flows turbine creating way too much back pressure.
That's interesting. Any theory on why SimonR32 (first post: http://www.skylinesaustralia.com/forums/topic/347726-kando-dynamics-turbo/) has been running the T67 25G for years without issues?
Thanks for providing input - I would definitely like to know if reliability has changed or is worse than previously evidenced from this thread, as I definitely don't want to be recommending a product which is going to cause people issues. In saying that, again I'm not like to recommend mismatched turbos to people anyway... so the likes of a TD05-16G6/TD06SL2-20G/TD06-25G should be comparatively safe?
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
