Kando Dynamics Turbo
SimonR32
Nothing inherently wrong with the rotating bits. The housings are likely to be physically small and not capable of flowing what the wheels can push. They do build turbos with housings more commonly fitted to those wheels.
If you want "bolt on" Kinugawa then maybe look at the TDO6SL2-20G.
Hey guys, My R32 goes in for a tune on friday. Im hopefully looking to get atleast 300rwhp. What do you's think would be an estimate of what im going to make.
The mods are - Stock Rb20det
Td06-20g 8cm sl2 v band on stock exhaust manifold
38mm Tial External Gate
18 pound boost
550cc injectors
255lph fuel pump
z32 afm
Nisstune.
    • Me too. Apparently the new version of Invision will allow some customisation so look forward to a 'Love' reaction and a new 'Like' icon.
    • Which injectors are you using? It's likely the fuelling is off also, so as above.
    • Awesome to know. I have a Series 1, and When pulling my front bumper off for the first time i realised my reo/crash bar was a bit worse for wear, and was going to try pick up a better one soon just so i can replace it. Someone is selling a full series 2 front bar and brackets for a decent price, so was going to probably reuse my brackets and install the new second hand reo/crash bar. I also have a genuine Altia body kit to do up, spray and put on, and not sure if that will use the series 1 or series 2 brackets for the front bumper, so having both will be handy, and knowing i can drill holes out to make stuff fit between series is also handy to know!
    • I should also say that the while they are different the only parts that matter are the center headlight supports and center bar from S1 to S2. The center bar will work, but the S1 has holes that clips go through into the S1 bumper. So if you were super cheap you could simply drill the S2 bar. Same thing with the side/wings. They have slightly different 'clips' but can be made to work. The center headlight brackets however, cannot. This is also where the GTR differs, which has a different center bar, and different headlight supports (to either GTT system), it also has different 'wing' headlight supports which is what I am calling under the headlight. However those CAN be made to work with the GTT Reo for a GTR front bar by a small spacer and a drill/tapping a thread into the reo because the bolt positions are slightly different. So people only really need the center brackets to go between GTT S1, GTT S2, and GTR if you are happy to do some tinkering.
    • Indeed  😃  Appears the site is back up now (migrated not updated) - kudos @funkymonkey & @PranK
