Hey fellas,
Anyone have a issue with their gearbox opening when changing gears under power?
My last 3 R32's have all had the issue and it drives me insane and I'm yet to come up with a solution. I'm just about ready to tech screw the stupid thing closed forever :)
Any ideas/solutions???
Cheers
Simon
https://www.sau.com.au/forums/topic/348185-r32-glovebox/
Hey fellas,
And no, never had a problem with the glovebox either!
Edited by blind_elk
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5600102
lol well played.
actually yes I have exactly the same issue.
in my race car the dash and glovebox are a little crooked from the cage install. As a result if I close the glovebox straight up it does not latch properly, but it looks like it is OK and stays closed until the launch. If you push it to the right when you close it, it is OK. which is a long way of saying....check it is latching properly. When closed properly it never comes open even crashes
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5600265
LOL FUUUUUUUU
lol well played.
Yeah the latch seems to leave a few mm gap when it is in the "closed" position... When enough force is added (through brutal gear changes) it just squeezes through the gap.
The latch isn't opening, just dodgy clearances... DAMN NISSANS
Edited by SimonR32
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5602409
I've had this problem. Bought a new glovebox and realised it didn't fix the issue so I just grabbed some pliers and bent some things in the latch... :mellow: It stays shut now
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5603394
do the gloveboxes in the 32 slide into place (can you remove them by opening then pulling them up, or something like that). if you can, then it may be worth looking at pulling it out and putting a bit of plastic or cardboard at the bottom of the slot that it sits it so that the glovebox sits higher. this should make the latch have better contact. or have a look at the latch and see if can be moved up at all.
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5604459
Thanks for the idea, I just got a set of plyers and bent the f**k out of it!
Now seems to latch and hold :)
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5607937
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
