Cihan is borrowing it, otherwise you guys wouldn't have your cars tuned. You can thank me later. :)
The Innovative is only $200 delivered, no gauge, as the informeter has an analogue input. It can simulate the stock o2 allowing you to stick it in the stock bung, although it should really be a meter or so down the pipe. Cheaper than a replacement stock narrow band o2 sensor too.
been thinking about buying one for ages, they make another one with a memory card in it so it logs without a laptop then you dump the files
i'm thinking about buying one to make into a temporary setup that can be whacked up the exhaust just to check whats going on (exhaust probe and 12v cigarette lighter plug)
Bought a runner spacer from Craig (thanks Craig!) and I cant install it until next weekend at the earliest dammit!
Will go on with plugs, and fluid change.
What software are you after? Ive got a few different consult programs for W7
i need software for the stagea and maybe some for R32 and S14, but the stagea stuff is the most important.
It doesn't cost much to get an extra bung welded in pre-cat if you want to run a wideband in addition to your stock O2 sensor. I have additional bungs on both cars.
What's the advantage of running the o2 and the wideband together?
both me and Jethro are running an eManage, it will throw a fault code regardless.
neither of us have the o2 plugged in.. its only there for economy at cruise i think... mine was fudged any..
It wont cause a limp or anything.. it will just throw a code and not try to retune timing..
If you want to see whether the factory O2 sensor is still working in closed loop.
If you have two cars you can buy just one wideband setup rather than one for each car.
If you want to tune the car you won't need to remove the factory O2 sensor.
i think our o2 actually fiddle with timing itself. everytime Cihan tried tuning mine previously with the o2 plugged in, the tune would just go out of whack on the next run.
i unplugged it, and it was fine from there on - that being said my o2 was f**ked. but i dont think its necessary if your tuning.
there is no vehicle specific software, consult is just the protocol that all nissans between about 1989 - 2002 use. and there is plenty of free software floating around. i've got a few, ECUTalk, Conzult Free, TECU, Nissan Scantech (i think this ones free). If you want to shell out some money you could use Nissan Datascan. even the Nistune software will perform consult operations.
If your looking for a good solid little program to check error codes, look at gauge readouts and some data logging than look at ECUTalk. its a great little program, i used to use it all the time before i got my nistune software licence. As far as i know there aren't any free consult programs that can run active tests, i think the free conzult can but its limited.
can you pm me with what you have please? my only working free copy (nissan data scan i think) won't work anymore
+1 on this, its exactly what i have done and for a couple of reasons, one so i can remove the wideband and use it on other cars for tuning, and two, you shouldn't be running a wideband where the factory O2 sensor is, it get way too hot for them in that position, a general rule of thumb is about 1meter back from the turbo outlet if you can.
also, most wideband units will have a narrowband simulation output that you can use to hook up to your ecu if you don't want to run the stock one.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
