nah factory wing, same as the one on Alex's PM35 and another one that was at the meet.
pic for you bigkev!
worth it purely because its my colour already
Edited by zei20l
lol it clips on, but there are 4 or 5 bolts underneath. youll need to remove the inside trim from inside the hinged glass tailgate section.
not a massive deal.
has your himount stop light died? mine too. i have a spare, but the non-wing models are different
Mine hasn't died- get back to me in 4 years time... then it will be as old as yours....:ph34r:
did you get a chance to check that diff out on the weekend? I know how far hassling you for parts will get me :P
nah i havent been there, but what am i checkout out on it? i thought you were coming to look at it?
I finished making the new fuel pump assembly today, all ready for the triple teflon braided lines. One Walbro HP and -6 line for each rail, it should just be able to max the injectors if I need it to. lol.
Hopefully the gtx turbo ships soon... :rant:
:worship: That looks like it'd set alarm bells off with ASIO :rofl: May have to get some details of your construction of this... eventually !
haahh thats some cool shit right there dude!!
not bad at all!! very clean
paint it black and no one will know its not factory.
how many PM35s do we have on here?
Cheers, yeh considering painting it black, or polish it a bit more.
I'm just not sure what to do with the breather line that usually goes back into the intake. Either make/buy a oil catch can or get a nipple welded on to it.
By the looks I need a new rubber joiner(from pipe to TB), it's starting to crack, so that'll be next!
just get a similar one like the blue silicone joiner you have.
then cut one side on a angle that suits the bend..or a bend silicone joiner
cutting the end is what I did and it works fine lol
make a nipple and put it back in if thats where its supposed to go. again, it will look factory and oil vapours will go back into the engine where they are supposed to lol
Not really. They go back in their because it was the easiest way from factory.
It's a proven advantage to vent them somewhere else. My RX7 has the breather go into a bottle... The optimal setup is a 2L+ bottle, with steel wool baffles and a drain back to your sump.
Oil vapour = lower octane of your fuel and grime up intake. Which we all know is an issue on VQ motors. When I ripped off my intake it looked like someone had poured a bottle of oil through the intake. (Given it probably had never been pulled off its whole life of 200,000km)
Yeh, i'll probably do that, or just get a silicone joiner the same as the black pipe, just a little more dollars.
Edited by JayM35
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
