I changed my oil today, used Motul 8100 Xcess. While I was doing this I replaced the stock sump plug with a Greddy magentic sump plug, and also installed a Greddy oil filter relocation kit. A Greddy OX-3 oil filter is fitted to the kit.
Now to go for a test run later to see if I there are no leaks. I know If there can be a problem, I will have it.:domokun:
car went to chasers on saturday to get the emanage back in. had a slight missfire with the emanage in but have been assured its fine and made 180awkw so everything appears to be in order! car pull so much stronger and cleanly now. love it.
Put a dump pipe on the car yesterday and mated it to the factory front pipe and then into the Kakimoto rear. A nice little increase in power and response I think from my butt dyno readings.
Kakimoto R?
wait do you have an m35?
lol....one day you'll get it done!!!!
I thought you had an AR-X for some reason!
Nope, RS. Didn't want an AR-X, not a big fan of the plastic bumpers, and reading here made it sound like it was a hassle to change the suspension.
Yeah, mostly me being a dickhead.
Cooked it proper like, think I have broken the tranny oil pump too which caused it to cook even more.
Was beating up on it for a couple of hours through the hills, then dropped a skid on some semi slicks no worries. Went to drop another skid but I think a combination of hot engine, hot box, hot semis, really didn't go down well :( Then add in the fact it was 1am, I was tired and cranky coz it wouldn't light up so I probably tried a bit too hard >_<
Now there is a dull rattle from the bellhousing, HEAPS of fluid in the pan at temp (with a nice burnt smell) and can't get any gear (can see the selection on the dash though). Diagnostics said Shift Solenoid B and Overrun clutch solenoid but I highly doubt those... the fact that there is a rattle, heaps of fluid in the pan and can't get any gear leads me to think the oil pump is busted. Got a spare torque converter from a 34GTT but not a spare box :(
Edited by bubba
Was it hard? Fitting mine tomorrow lol any tips?
Fitted nice white LEDs to cabin lights (standard) plus white LED strips to footwells both front & back.
Wired them to come on with door open (not running all the time) which gives a nice ambience when you first hop in.
You have to choose colour, brightness and method of operation carefully. It can be a fine line sometimes between classy and RICER :laugh: .
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
