I'm actually hoping they poke out a bit, just to get a nice stance. Are the rear guards wider?
Yes, and as you lower; they tuck in (negative camber) much tighter than the front. With a roll on the guard lip I'd say the rear is 15-20mm wider.
Edited by Daleo
Yep, and the rears can be rolled a bit, the fronts are already rolled. Those sizes will stick out about 10-15mm I think, possibly more than 19 inch tyre stretch will help with but you wont know until you put them on. I would suggest test fitting them before you buy.
I know my 17x9 drifteks are perfect at +30 with a 255 with tyre but with 19 inch I couldn't tell you.
Yes, and as you lower; they tuck in (negative camber) much tigter than the front. With a roll on the guard lip I'd say the rear is 15-20mm wider.
Do anybody make an adjustable upper arm to solve the neg camber issue?
So if they are sitting flush the +22 should look ok. :)
hoping some one on here has a rim somewhat like I'm looking at...
Who else has 19's and what are the size/offset you are running :)
Cheers.
Plenty of different stuff available for 350Z/ G35 in the US (think Ichiba,etc), but going that way will actually REDUCE the wheel to guard clearance.
Cheers.
Maybe shoot spoolin12 a PM, I'm sure his offsets must be close to this after the fitment of his Akebono Brake setup, due to the required spacers to clear the calipers.
Edited by Daleo
looks like it...my spare looks the same.
:thanks: I wasnt too worried, given thats how it looked when it came out, just curious :)
if it sealed completely i dont think it would idle lol
for sure, no air = no go! But I thought if it was designed to be closed when turned off, then 'idle' would have the motor opening it ever so slightly - possibly the amount you see on the pictures - maybe more!
You may find that once it it being controlled by the ecu, it actually pulls closed. Most throttle bodies have an air bypass port to control idle, and the butterfly seals completely.
Edited by Daleo
yeah spoolin has 19x9.5 +40 with a 12mm spacer so effectively a +28 offset... but they do stick out a bit - he has stretched tyres and they dont scrub.
but talk to him about tyre wear. with that width and offset you cant take out much of the camber or they will scrub the guards, so tyres wont last long.
Edited by bbenny
Went a bit overboard on eBay today, picked up my slimline fan ready for the front mount intercooler, and ended up getting a Nismo dash after putting in an offer... Bit sad, but ah well!
Also picked up a Repco equivalent cabin air filter. Got the carbon one for $25.80 trade. They were out of Ryco ones and I figure this would be fine.
Going in tomorrow with the runner spacer (finally!).
Took the car for a thrash through the hills... man there are some idiot drivers up there, but makes me even more excited for the sway bars! :rofl:
I was checking out that Nismo......wont work on my car though unless I change my tyre size
Why's that? Just be out?
My stock speedo is already out around 10%, so doesn't bother me heaps. Will get it calibrated when I get new wheels.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
