When did u get the emu Leon?
What EMU? It's more like a kangaroo lol.
I think I've been misunderstood somewhere along the line. I've only got the stock ECU & no Emanage. In fact all my testing is done on a stock car except for a turbo back 3" exhaust.
I was trying to beat the throttle restriction via a DIY "backyard" mod and I thought I had it beat last night after a cracking drive. But this afternoon when I took it out again I had gremlins in the system. So now I'm not convinced.
As you may appreciate, I've been thinking, measuring, researching etc this for some time & so when I come to write up my findings it's taking me a while to type it out.
Since I don't have a magic fix for everyone right now (like I thought i did last nite & this morning), I've decided to throw it open to others for their input & I'm happy to do more R & D and testing.
I'll be starting a new thread a bit later (tonite I hope) with all relevant info & we will see how it progresses.
Cheers.
past week stag has seen new Tein coils courtesy of streeter, ganador mirros and ordered my new headunit with reverse cam, digital tv, nav ect ect :-)
What did you order? I'm still looking for something with similar features...
Cheers.
i have a spare throttle body if you want one off the car to play with?
Yeah, that might prove to be a good idea. I'll get back to you if I need it.
Thanks.
I bought some Pirelli P zero's today. 235/45R19 << who said it doesnt exist *fkn TTF*.
Jason(prince Skyline) knows how much I paid for em lol.. n no not a Re-tread. brand new :nyaanyaa:
Took the Daily to Winton instead of the usual Track car, did a 1:48.5440 which was great fun, though it drinks like Fatz when being punted hard :P
mate sent me a pic of your car parked near his (Grey Evo 8MR)
good to see stags getting out on the track, might have to put mine out there soon
Pretty good time for an overweight barge! :worship:What tyres are you running?
Crappy ones that came with the car :P Supercats I think, not exactly grippy, but meh, good enough to roll around on and I wasn't there to break records. Car is VERY safe to drive on the limit, but with more grip and more roll stiffness I reakon I could get it down to maybe a 1:45, shift kit and LARGE transmission cooler with water spray might also be necessary, so not gonna happen .... yet ;)
Informeter turned up, wired up and ready to install.
But best part is...
MY FLANGES ARE HERE!!!!!
Being the first M35 for AM Performance, I've had to wait for everything you usually wouldn't, including getting the flanges laser cut. Making it easier for the next person through!
Should be ready to pick up tomorrow or Sunday (might have to beg Brad to give me a lift to pick it up :worship: ) and sounds like it'll be worth the wait. Straight through 3" no restriction :banana:
Iain, AM Performance wanted to start doing M35 exhausts, so they're using my car to develop the jigs etc. I've asked for an exhaust which doesn't drone on highways, and have been told not to complain if it's too quiet :whistling:
They're custom making the whole system, from the turbo back, and will sell it in sections so you can buy a dump, mid or end pipe. I'm really impressed with the way Andrew makes them, he can make a straight through exhaust and uses special sound deadening material to make his own muffler around the outside (or inside, depending on what you want, this is what he does on R32 GT-R exhausts and it looks amazing!).
I'll have photos when he's done if you're keen. Best part is I know its great quality, and I can spec it how I like, so I'm getting it slightly customised.
You got an external wastegate Aaron?
He wishes. :P
He went for a stage 2 Sierra highflow, now he has boost spike issues as the stock wastegate was way too small. (so is the housing) I opened it up for him a few mm and it made no difference, it needs a larger wastegate flap.
lol. I have no idea about external wastegates, seem pretty costly. Can't he just fit an external wastegate if the stock wastegate is way too small?
Hurry up with the Garrett Scott! I'm going to need a new turbo, and your route sounds heaps better than a high flow!
It is, but I have a T18 in the driveway getting a vvti 1J shoehorned into it. Lots of fabrication work to do. Perhaps I will push it into the street and do my fuel system first. lol.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
