put my remsa pads in today and gave them a quick bed in (probably need more tho)
i still have a squeal (thought it was the old shims and pads up front) but it could be the rears :(
can't complain about the pads, great bite and grip, haven't heated them up much yet tho but i think they will be better than the old pads
fitted the BC racing suspension today...against dale's recommendation, i lowered the fronts a bit morewhistling.gif
now i got a car that is slanted to the front, checked underneath, distance between undertray and the road is about 6-7cm...took it for a test drive, couldn't see the headlights of the cars right behind me unless it's a 4wd pinch.gif
gonna raise up the fronts tomorrow then get a wheel alignment done, the rears are toeing in pretty badyucky.gif
that should happen on pretty much all auto transmissions. except ones that have a 'neutral idle'. ohh and start-stop equipped cars
Nah it never did it before the shift kit. More like a thud. Doesn't do it if the cars warm though
i picked up out NM35 Stagea from the compliance shop yesterday, registered and ready to go! With a day off today Im trying to decide if I should fit the Tanabe sus (at home on stands) or wait until next week so I can get it on my mates hoist.
Overall just excited to have it and start some work on it.
do it on the stands, just have a spare jack handy for the rear spring!
took me a few hours overall!
give you a good idea of whats under there too
Let me know when it's fitted, I want to check it out!
Like a bull out of a gate!!!
Nice way to start ....1 day into having the car!!!!
.....I think I lasted 3 day's before I did a full dump back exhaust and another 2 weeks before the wheels....and the list goes on and on and on ect!.....4 years later and 2 things left to do!!!...maybewhistling.gif
Edited by Jetwreck
this your next mod?
