put my remsa pads in today and gave them a quick bed in (probably need more tho)
i still have a squeal (thought it was the old shims and pads up front) but it could be the rears :(
can't complain about the pads, great bite and grip, haven't heated them up much yet tho but i think they will be better than the old pads
fitted the BC racing suspension today...against dale's recommendation, i lowered the fronts a bit morewhistling.gif
now i got a car that is slanted to the front, checked underneath, distance between undertray and the road is about 6-7cm...took it for a test drive, couldn't see the headlights of the cars right behind me unless it's a 4wd pinch.gif
gonna raise up the fronts tomorrow then get a wheel alignment done, the rears are toeing in pretty badyucky.gif
that should happen on pretty much all auto transmissions. except ones that have a 'neutral idle'. ohh and start-stop equipped cars
Nah it never did it before the shift kit. More like a thud. Doesn't do it if the cars warm though
i picked up out NM35 Stagea from the compliance shop yesterday, registered and ready to go! With a day off today Im trying to decide if I should fit the Tanabe sus (at home on stands) or wait until next week so I can get it on my mates hoist.
Overall just excited to have it and start some work on it.
do it on the stands, just have a spare jack handy for the rear spring!
took me a few hours overall!
give you a good idea of whats under there too
Let me know when it's fitted, I want to check it out!
Like a bull out of a gate!!!
Nice way to start ....1 day into having the car!!!!
.....I think I lasted 3 day's before I did a full dump back exhaust and another 2 weeks before the wheels....and the list goes on and on and on ect!.....4 years later and 2 things left to do!!!...maybewhistling.gif
Edited by Jetwreck
this your next mod?
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
