So Tonkins don't recommend alloy ones at all. I brought it up a few times and every time he just told me to replace it with a standard one. His main argument is that they cost lots of money and if they leak they can't repair them.
FYI: Koyo V2588 from Street to Track for $545 delivered, Mishimoto MMRAD-G35-03 $475 delivered.
Still not sure what to do!
Umm, have they heard of welding?
Your cars white, it doesnt show the dirt like a dark colour. Mine had gone probably 2 months without a wash :ninja:
I guess aiming for around 8am? Far too early for a Saturday. Given they wanted to run all the AWD's first, and theres still a few gaps early on - Id suggest we may get bumped 'earlier' to fill those gaps.
8am is way early, i'll have to leave the dirty south before 7 am!!!! on a saturday!!!! GAYYYYYYYYYY!!!!!!!!
But a new plan is forming..... finish work at midnight, drive to gillman, sleep in stagea, make noise on dyno, laugh at pitiful power figuresthumbsup.gif
A crap alloy radiator is worse than the stock one apparently, they must be multiple pass for the higher cooling effect to be considered an upgrade.
I think they are saying if the fins leak they cant braze them whereas the stock one can be?
V35 Koyo rad ordered. Taking suggestions on trans coolers. Is it worth getting one with a thermostat so the oil warms quickly on the cold mornings?
Does your new radiator have a section to cool the transmission like the stock one?
If it does when you install the trans cooler just make sure it is still using this part of the radiator before going into your transcooler and the engine will warm the trans oil.
Nope, very few of the options do unfortunately.
fitted my z32 and nistune tonight, havent started it yet as its like mid night and my wife is sleeping. hopefully it runs in the morning as i need it. does anyone know if i have to remove the plennum to change the injectors?
SAUSA Dyno Day today, made 161kW and 566NM at 15PSI. Stock bar the exhaust and Blitz panel filter.
Then sold the Pimptara while I was half way through cleaning it! Score! Sold for a bit less than I wanted but rego was due tomorrow. Oh well.
Gotta be happy with that, hey.:thumbsup: . And I mean both bits of news.
Happier with the torque tbh. Already planning more mods! MOAR POWAH!!! As for the Pimptara, not really happy about it. Grew very attached to that car, lost heaps on it, and the guy who bought it was a bit of a dropkick.
Got the Emanage Thursday, so by the next dyno day should have a bit more.
What was interesting was I made more torque and had more boost than Dunc with his highflow, intercooler, etc, but I was down 16 (I think?) kW.
That torque isn't correct. That's tractive effort not engine crank torque.
A very good power result none the less.
Is it all wheel kw or rwkw?
We ran back to back, so I wouldve thought the torque readings would be comparable? Not my forte unfortunately.
I made 177.7 awkw though, it was an awd dyno. My AFR's are essentially a flat 10, boost peaks shy of 15psi. Things to work out :thumbsup:
They may be comparable on that day on that dyno but it's still not crank torque. It's tractive effort, being the effort it takes via the wheels to turn the rollers, this is different to a true crank torque. I would assume it would be mid 400 nm at crank at that power level given stock is 410nm. You simply won't gain over 150nm from an exhaust and filter.
What mods do you have for 177.7awkw? If you lean the mixture to a safe 12:1 you will see some extra power.
Well done, nice results.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
