lol how can you forget that??
ohh yeah, when you remove the white door, dont break the tab off the end of it. i did with mine. lucky i had a spare :P
I did exactly the same thing...
Took my brilliant looking (but not functioning correctly) air intake off today. The BOV return pipe had a lot of oil in it. I reckon I needed a catch can bucket on it LOL.
When I got the bottom section out, there was oil pooling in there, and in the turbo housing also. So I start thinking that maybe the fuel smoke was partly/mostly oil smoke & my turbo is on it's way out. Bugger, I am quite attached to the factory turbo & didn't really want to be pulling it off & rebuilding.:(
Anyway, I put the factory intake back in & restored all my tuning adjustments so everything was normal & went for a short drive. Surprisingly there was no smoke (that I could see, & it was hard to miss before), so what the hell is that all about?
I checked the BOV return & there appears to be less oil (i.e what was there is disappearing) but I won't know for sure until I'm driven it a lot more. I checked the oil level & it was low, so the oil was certainly being consumed (or just filling up my intake/cooler/throttle body etc) & it's only been 3250km since the last change - but that was over 6 months ago. Note to self - "drive car more". lol
Q. Why was there oil in my intake/BOV return with the bigger air intake? Is it still a sign of impending turbo failure? BTW, it's not making weird noises or anything that would normally indicate this to be the case, and it's still running stock boost.
The only thing I can think of (in my end of work tired induced state) is the different tubing is actually pulling oil in through your PCV?
That's not a bad guess actually. However, that's one thing I can rule out because I installed a catch can on the PCV line & it has clear tubing. There wasn't even a smear of oil in that.
What if there was sufficient extra airflow to push 10yrs worth of oil build up in the i/cooler up to where it shot back out the BOV? Mmm, but that wouldn't explain the engine oil consumption... (also my end of week, tired mind throwing an idea around).
Clean your intercooler out, or buy a new one from Cam, and see if the issue continues?
Ive got nothing, although i know there was somewhere other than the pcv that a catch can is recommended for...
There may have been oil pooling in the stock breather hose at the head end which ran down when you plumbed it in? My catch can usually has bugger all oil in it, just condensation.
Don't give up on the intake will you mate, just try again. I made a few before I worked it out. Cheap tig and some stainless? :yes:
I have both on mine, neither build up much but the intakes are noticeably cleaner. I still get a little oil in the intake even with SS wool stuffed in the can.
The hassle with a catch can is having to drain all the water out, probably not an issue in warmer climates.
Nah, won't give up that easily, but I didn't get any noticeable gain from the intake anyway, not that I was expecting much. I don't have enough other mods to have really benefitted from it yet.
At this stage I was just hoping it would be more efficient & therefore have some fuel consumption gains, but wasn't in long enough (nor working properly) to tell. Now I'm pleased it looks like the turbo has some more life in it. :happy: . Job for another day I think.
Few new things
New Oil
New Oil Filter
New Transmission Oil
Transgo Shift Kit
Suction Pipe
E Manage wired in
Boost Controller in
Transmission cooler & injectors to go in next weekend and then to the Dyno! :thumbsup:
Few new things
New Oil
New Oil Filter
Transgo Shift Kit
Suction Pipe
E Manage wired in
Boost Controller in
Where are the pics of the Suction pipe?
Are you hitting Boost cut now with the new suction pipe?
Had 4 wheel balance, rotate and wheel alignment yesterday.
Left at 7am to drive to Albury from Sydney only to find at 110kp/h when turning left had a big vibration in the steering.... very odd. (no vibration when driving straight or turning right)
Wheel nuts checked, so not really sure what is going on. Had to turn back to home and swap cars for the trip.
Will go back to the tyre shop and get them to check the front right tire and alignment for any irregularity. If that shows nothing I am thing new wheel bearing for the front as they have done 148k.. Hope I can work this out quick. :blink:
Few new things
New Oil
New Oil Filter
Transgo Shift Kit
Suction Pipe
E Manage wired in
Boost Controller in
Nice, wheres the pics?
Who's doing the tune? :thumbsup:
Did my oil+filter change today
And gave the car a polish, ready to the vic cruise
last weekend i finally got round to put on the Whiteline swaybars i got back in the group buy
would have done it a lot sooner if i knew there was that much difference
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
