Hmm I thought the dolphin intake was of dubious quality?
I wouldnt say the quality is dubious, its a really solidly constructed unit. The dubiousness would be the effectiveness it has on the restriction that needs to be removed.
It only replaces the black plastic bit between the AFM and the rest of the intake.. obvious the AFM housing is in this photo (not mine) but it illustrates it fairly well.
Dunc should be able to tell us now, but he's probably off driving it to see what it's like!
Have you got any photos of it out of the car Dunc?
Car is boxed into the garage and I cant be bothered moving stuff off the driveway :domokun:
I didnt bother taking any photos of it out of the car, it looks identical (+ engine dirt) to the photos on Dolphins website.. you can see exactly how it mounts up based on the kink compared to the stock plastic unit :thumbsup:
I'd be curious if you notice any difference then. It doesn't look like it'll make bugger all difference to me. Same shape, except metal instead of plastic?!
Got my rear sway bar onto my car last night....rear end is working much better.
Bald Hangkangs in the wet with LSD and 2WD is a little bit of fun......note to myself!!.....install windscreen wipers on the passenger and drivers side windows! laugh.gif
What is the plan now? I've seen you in a few different discussions now and it sounds like it might be a bit unique...
Sussing out a few 340mm rotor combinations to run with an R32 GTR caliper/ offset bracket. If it works out, I'll detail the whole thing; could be a budget monster upgrade.
A chance chat with another forum member has got me motivated again.
Could also end in tears; we'll see.
Edited by Daleo
Interesting. 340x32?
Could be good, but when the new setup runs out I'll probably go 350Z Brembo or Akebono.
That's the plan, hopefully be able to bring it in under a grand, closer to $800.
i'll be up for that one Dale, got the callipers already :)
Apparently there was some industrial action in the states, and my BCs are still sitting in a container somewhere >_<
Now I'm unlikely to get them for another 2 weeks :rant:
Car is getting a service and wash today though, have to clean the bugs off.
I was really lucky and got my Tanabe Sustec coil overs from JDM Concept when he had an end of financial year sale so I got them delivered for the ultimate bargain price of $740 nyaanyaa.gif Thats half price and it was the only set he had on sale. I love the ride and most importantly the boss doesn't complain about them being too hard.
Pulled bumper reo and intercooler off yesterday and this morning. cleaned intercooler, not very dirty though, cleaned lights while they where out, look a little better. cut reo a bit in an effort to get my front bumper sitting better over the intercooler, reo sits heaps better but front bar still out of adjustment though. bad. guess i'll have to put the sikaflex back in to hide the gap, and save for an R34 conversion kit haha
Absolutely nothing yet cause I don't pick it up till next Sunday lol. But 3" dump pipe back exhaust will be fitted straight away and have nismo gt le mans group A turbos, jjr adjustable cam gears, 750cc injectors and walbro fuel pump (if needed) ready to go and will be getting haltech platinum pro for management. Will keep updating progress
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
