took car to nissan service to sort out the ECL issue
if u guys remember, the codes that came out were 1110, 1111 and 1135
turned out there was an opened circuit at the intake camshaft on the passenger side, so after an hour's work to fix the wiring and $121 paid to nissan service, no more ECL coming up...happycheers.gif
the guy at nissan service asked me how i found out the codes without OBD2 scanner, i told him i talked to the ECU and it answered me lolwhistling.gif
lol just a short drive to the city this morning and i used a lot of fuel
nah its the same as a t30 xtrail - 22680-6N21A
thats for the hotwire only, not the whole tube - which isnt required anyway
Found a couple of links;
http://www.nissanpar...2680-6n211.html
http://www.cyberspac...n-uk/p1178.html
Slightly Cheaper price.
Edited by Daleo
Link doesn't seem to work?
Dunno what happened to that one, Google the updated part number (can't remember it, posting from phone) and it'll come up. Price was $190 aus.
Try this one :)
http://www.cyberspaceautoparts.com.au/contents/en-uk/p1178.html
Which Nissan dealer Syd?
it's the camberwell one cam, they were quite nice although they admitted my M35 was the 1st one they ever seen and with some luck they saw another one drove past on the same day lol
Cool, sounds like a reasonable dealership (Yes, the shock is overwhelming!!)
Went to Jb Hifi yesterday before work and was looking at getting a new cd player for my car but wanted to keep the HDTV i got in my car atm. So the guy there said i can keep my oem cd player in my rx and just get a FM extender to get all the fm stations in australia. Well this cost me $25 from autobarn so i was strapped. That was until i took my dash apart and seen that our aerial plugs are twin pin units and the fm extender is a single. So today i ordered the adapter from the UK for it. Cost me $75.00 AUD so all in all im still happy i get to keep the OEM unit. Just got to wait a little longer until the adapter arrives.
http://www.nexxia.co...ategory=Antenna Adaptors&section=Car Audio
I got my aerial adapter at auto barn for $10
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Edited by Ross
Fitted the new suction pipe toady with the help (should read totally lost without) Craig (aka Jetwreck, is there any thin on cars this man can not do).
This was certainly at the limit of my ability and patience to work on cars.
Thanks to Scott for hit great fabrication, only a slight mod of cutting a grove into the bottom bracket of the suction pipe so it could be placed over the shaft of the bolt.
For anyone looking to do this mod make sure you work with someone who is a contortionist as there is no bloody room to work in.
Net result is a good fit with a little bit of tidying up to be done on pipe work but the car feels even better down low in the rev range. Not had a chance to really test the top end as I am conscious that I need to finalise things under the bonnet and aware that I am currently running 17psi and want to be careful of hitting fuel cut.
thanks all.
Cheers
Andy
Had my mate in give the wagon a good cut and polish and wax job while I'm in renmark for the weekend. Looks very
Nice now. Just need to wash it again when I get
Home and give it another wax to finish it off.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
