The thread I was looking at yesterday said there was a cross brace in the way, but it could be possible?
Apparently the Bose amps fit under the toolkit, so I'm hoping normal aftermarket ones do too.
The only thing i would be worried about there is sufficient ventilation.
Oh so the standard Bose unit isn't powered? Has external amps?
That's what I read yesterday, Iain would be able to tell you for sure since I'm pretty sure he wrecked one.
Did you check out this thread? http://www.skylinesaustralia.com/forums/topic/255109-m35-stereo-lots-of-piccies/page__hl__speaker
Great thread! I have a fold out single DIN TV/DVD/GPS at the moment. I'm really keen to replace it with an OEM unit and a single DIN that will display through it.
I just checked out my car and nope, there's no way that one of those long powered subs could fit under the tool box. A small enough amp could definitely fit on the right hand side though.
Come check mine out then. I do want to see your radiator and trans cooler. Was going to look on sunday but you piked!
Piked makes it sound like I didn't do anything. I wish! :rolleyes: Haven't had a weekend off since being back in Australia..
my ariel leads came in the mail from the UK today. So installed them along with my FM Radio extender. Now i have FM radio.......... Oh the sweet sweet sound of no more AM radio stations. Next is a service. . I have a feeling that my turbo is leaking oil. Started smoking on that side of the engine after not starting engine for a week. I have suspected it as i have had blue smoke upon startup for a few months now. Might be time to check my turbo seal aswell.
that would be such a relief if its just a rocker gasket.. Do you have a part number? Prob get both sides done at same time
Take your VIN number to a Nissan dealer. They'll have to order the gasket regardless, nothing else is a match. Cost is around $29- $30.:thumbsup:
Finally got the dump pipe fitted up today after having Captain Thread fix 2 busted studs yesterday. Big difference in performance from the stock dump.
I also noticed an increase in boost, not sure how much as it now seems the factory boost gauge is maxing out. Does anyone know how much boost increase they got from the dump and if the stock turbo can handle running a couple extra psi without destroying itself? Im just a little worried that by fitting the dump to try and extend the life of the turbo, the extra boost with destroy it sooner than before.
Also anyone know where I can get a flange gasket to suit the stage flange? It appears to not be a 3" flange gasket.
Edited by slippylotion
3psi, thats more than I expected. Do you have an a/market gauge fitted?
The oil feed won't make a difference to the extra boost, its the extra shaft speed and heat that the ceramic turbine wheel will see that will cause it to go.
I know that the ceramic turbine wheel on the RB series don't like any more boost than 12-13psi, after this the shaft speed and heat cause the wheel to break or shatter.
No thats based on pressure measured on the dyno. Stock is 12 psi, on sausa dyno day was showing 15.
Scotty drilled his banjo out and i think he was running stupid amounts of boost without it going bang?
My banjo restrictor wasn't drilled but I cleaned it out, ran 19-20psi on the stocker for over 4 months with no issues.
Our stock 14psi boost would be too much for the older RB series ceramic turbos.
So you used a boost controller to up the boost more than what the exhaust/dump gave?
Are the turbo's that are dying from the exhaust wheel coming off or the core dying due to seals or bearing failure?
If the bearing assembly starts to fail; the exhaust turbine will be able to make contact with the housing; thus breaking the fragile ceramic blades.
I don't think any of the failed turbos have actually dropped the exhaust turbine; a-la RB turbo; only smashed the blades.
The reduction in heat buildup around the exhaust turbine by fitting the dump pipe, far outweighs any risk of failure due to excessive shaft speed IMO. I fitted the dump by itself on a factory exhaust and I'm convinced it makes the turbos life easier.
You are limited in a standard configuration to around 14/15psi anyway; due to the restrictor in the wastegate line. Even with a full 3" system and 100cspi cat mine won't go over 15psi.
With the 7psi actuator its hard to run any more than that, even with a controller. You may get 20psi midrange but it will always drop to around 15 by redline without increasing the spring tension on the wastegate.
The exhaust manifold pressure literally blows the wastegate puck open on boost bypassing the turbo hence welding a stiff spring to the actuator to hold it better.
All the stock turbo failures I have seen have been due to oil starvation/heat on the rear bearing as Dale mentioned.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
