Got the new 3.538 diffs in.....got some good umph now!!!!
My fears of the speedo being out are cured.....speedo and gps are exactly the same differences as they were before.
Care to explain how a change in diff ratio makes no diff (oh look, a pun) to the speedo reading? Am I missing something obvious?
Installed my new ECU this weekend.. NISMO Sportstune :banana:
Very first drive it is obvious the difference with the car being a lot more toey of the line. Best part to be experienced is in the mid range now coming on much stronger and faster.
Next step to put it on the Dyno and see what the AFR's are like and what the actual power out put is.
Is this enough power.. :whistling:
because (as i mentioned ages ago) the speed is taken from the ABS sensors on the OUTPUT of the rear diff. therefore no matter what ratio the diff is, assuming you dont change your rolling diameter, the speed will always be correct as the speed is measured after all the gearing.
where'd ya get that ratio, 34 gtr? I was thinking the same thing today.....
btw hills have a 4wd dyno. what computer?
Ratios are from then nm35 vq25dd or the pnm35....
....Hmmmm waiting for mark to give me a buzz back on the dyno.....to much longer and I'll be going to Victoria for a touch up!
Edited by Jetwreck
The Nismo ECU's.. how do they go with economy? Better/worse?
Emanage is a piggy back...so it needs an existing ECU to control.
The nismo ECU has certain "awesomeness" in it that makes the car a bit better to drive....and speed cut too I think
Craig's car has the Nismo + emange combo...
better.......you have an economy setting, it uses the snow button!
Worse......the drive is a lot more inviting so you tend to get up it a little more.
I think the main thing is no speed cut and no throttle restriction isn't it?
Has anyone with the Nismo snipped the brake wire?
Don't need to worry about that now though... :whistling:
I think he means with the fcon, the stock ecu still controls the throttle though. There are 4 wires extra in the loom plug I can't account for which may make some changes, not sure.
Doesn't explain how the throttle changed on my car.
Both much more responsive and also more soggy depending on map selected...
Without the infometer you are only guessing though. It could easily be tune related.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
