You getting a cat in there somewhere?
I still have the stock dump pipe which has a cat in it.
Does the M35 chuck a CEL if you have a decat pipe? Need some sort of resistor or something?
There is no wiring to the front pipe cat, no code has been thrown yet though I do still have the stock dump with cat
Edited by Ross
Im unsure if the dump has a Cat sensor, never really had a good look in there due to lack of space.
Already having a cat back in place, installing the front pipe gave a noticeable mid range power increase. Exhaust noise level is slightly up on idle and power but nothing huge.
The most notable change to the noise is the idle now has a slight "throb" to it, much like many RB engined cars.
Aren't we all funny bastards tonight?! :nyaanyaa:
I'd think you'd be better off getting rid of the cat in the dump pipe, going with a nice new dump that actually flows, and putting a high flow cat in the Kakimoto pipe?
And no Jase, no cat sensor! :banana:
Nope, no sensors after the cat, just the narrowband right after the turbo. Now you need one of my dump pipes :whistling: although the Kakimoto has a restriction at the front flange you will need to enlarge...
I can do one for $450 in stainless with heat wrap, lower gaskets and bolts, o2 bung etc. You will need to source some shorter studs or shorten the stock ones.
Let me know, im making a few up this week. :thumbsup:
lol a few?
This is excellent news!
Anyone that is running the Neo Racing oil - are you using the Platinum 10w40 or the Gold? The service interval difference is big but I don't do that many km's and will change the oil well before 40,000kms anyway.
yeah, I have. Good stuff.
40,000 is a bit optimistic though. 12-15,000 or normal driving is plausible though.
Supposedly if you change the filter at least 3-4 times during the 40,000K's it should be alright.
Me, I think I'll just stick with a "full" synthetic for $55 and change every 7,500k's.....
But you'd be changing the filter without changing the oil... would you really want to do that?
I think I'd rather stick with my 5000k changes, depending on what the Motul looks like when I drop it.
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
