Is it true you need 19 inch rims to clear these? Been looking at these for a while.... very jealous :)
:yes:
:no:
ADM 370zs have 18" wheels over the brakes. So no, you don't have to run 19s.
I do think you'll have to try hard to get a wheel with offset/ spoke clearance to fit them though, and thats when 19's give you that little bit of advantage.
:no:
Damm, that could be the deciding factor for me not getting a bigger set. I think the 355mm Akebono BBK is excellent value, but slim chance of those fitting. May have to print the template one day to double check exactly what will fit.
:no:
I thought that they had the Akebono 'Sport option" like the 350z did with the Brembo upgrade... with 18's, non Akebono but they get 19's if you select the Akebono option
Hmmm.... would appear that they were standard an all 370z's over here. Oh well, there ya go. Get a set of 370z rims Leon... have seen them advertised under $1k on other forums
Edited by iamhe77
Yes they are a great value BBK. Just be aware that the stock rotors are bloody heavy. I dunno if PMu stuff is lighter but you would have to sell your kidney to obtain PMu rotors I'm guessing ($$$) . I think there has been some 2 piece rotors brought to market by someone to try to lighten the kit up a bit- but the source evades me ATM.
I think the sizes are teh ghey. Their staggered for a start, and I think the fronts run a really high offset? like +47 or something?
Nice placement Leon, that's where I was hoping to fit the wideband. Have you got some better close up pics?
Ask & you shall receive. PM sent.
Stoptech
Thanks mate, much appreciated.
Stoptech
I think DBA do a 5000 series T3 multi piece rotor for 370Zs - worth looking into.
nah caltex eflex. when ramped up it did crack 300 but it averaged it to 297-298 cant remember scott will be getting the graphs, just hypergear turbo full exhaust n dump and intake (made by scott) and 1000cc injectors n emanage ultimate, we drove it up there untuned on scotts old map and it drove it a standard car, still does very nice to drive
fitted a new cooling pro return flow cooler nd jjr front and dump pipe to my car last week. not exactly direct fit for the Auto's, but managed to get it squeezed in without cutting front reo bar (twisted lower part slightly) nd front and dump pipe slightly short so from cat back all had to be moved forward nd trans bracket removed.
got car booked in for shift kit on tuesday. nd then got it going on for a dyno run at the SAU dyno day then get it tuned after that some time as i need to start saving money for trip
Nice work - good numbers! But how the hell did you get Hypergear to do your turbo so quickly? Mine took nearly a month to get back to me & I know when Scotty dropped yours off..... Must be who you know I suppose :)
Did you get the engine cover on and hide the Emanage away yet? It should look as stock as it came in. :)
I guess it helps that I dropped it off and had him under the pump to pick it up. The Easter holidays wouldn't have helped either. I'm fairly sure he outsources his machining work so time can blow out as you know. Is it on yet? What wheels did you end up with?
scotty engine cover is back on ur intake pipes r black so is the drivers side cooler pipe, emanage is hidden and painted the cooler black today nice and stealth :P been driving it alot today the mrs drove it she loves it, i launched it today hard..... well yeh u can guess how that went hahaha
Brief run down of the mods that obtained the above?
Auto Box messed with?
Shift kit
Full 3 inch exhaust with custom dump/front pipe
Hypergear highflow
HDI cooler
3 inch intake
Xspurt Bosch 1000cc injectors with plug in adapter
Emanage ultimate
300lph Deatschworks fuel pump @ 14v
Looks completely stock and legal with the engine cover back on.
So the speed limiter isn't defeated? And what's with the boost control, Thought it'd be flatter than that?
I have given Marko my SLD, as long as the Fcon gets rid of speed cut...
Boost curve isn't too bad, I like the power curve, its like a V8. (Stao didn't open up the wastegate so it spikes to around 21psi or so.) We could have bumped up the midrange a little to flatten it off but it drives great either way.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
