Got me one of these....... :yes: Aha yes I did
Will be a while till its on, as I'm waiting till I see my knee specialist at the end of the month. My last visit was..........lets just say less than encouraging.
Still, I'm soooo happy I bought it. :woot: :woot: :woot:
Nice.....I like it!
Detailed mine, and put it under a car cover again (sigh... I wish I had a garage: that way I could actually SEE the car when its not in use!). Pretty sure I'll be whipping the covers off again soon: the weather's starting to get nice and chilly again!
Had my AFM die on me. Boosting up a hill the power just cut out completely, it would barely idle and wouldnt rev. Fortunately i managed to limp the car home by disconnecting the AFM.
Fearing an expensive replacement was on the cards i soaked the AFM with some contact cleaner, let it sit over night and then tired it out in the morning. Amazingly the engine started up great, idled perfect and drove fantastic. In fact its driving better then ever, i went on a 100km drive this arvo with a whole bunch of blasts of the throttle. Fuel consumption is better and revving feels a lot smoother.
I'd recommend giving your AFM a clean even if its functioning well. Next weekend i'll try cleaning the wife's V35 AFM which is working fine to see if it shows an improvement
Serviced the car last night, oil (trying ULX110), filter, replaced belts, air filter and spark plugs (NGK)...... My car had a slight miss under big load and my economy was pretty average (6/7km per litre) One of my coils was covered in oil (the side that I had my rocker cover gasket changed under warranty) .......needless to say I was pretty impressed. Also I had 3 different kinds of plugs in the car NGK Denso and some wierd jap one WTF, all finger tight (washers on bottom of plugs werent even crushed) :unsure:
Wat? Your kidding, dealer serviced?
Thats a job I would be doing myself, so you can check the plug tubes are clear of oil. They wouldn't even tell you by the sounds of it...
I service my car but haven't done the plugs until now.....I am a qualified mechanic, but when the car was in warranty period (3 months) I got rocker cover/ srs light/ swaybar links/ disc machine blaa blaa done, As I figure I am paying all this money, I am not working on my daily when I don't have to.....
Also when I got it onto the hoist i have noticed I have a couple of very bald (camber) rear tyres and most of my bushes in the front need replacing, so at last I have a reason for changing wheels and tyres instead of the chrome gayness. Will also be needing bushes ASAP
Now just talking to the guys that did the warranty work. They did the outer rocker seal and the inner isn't serviceable (around the spark plug tubes) and you need to buy a new rocker cover or sealant the shiz out of it and cross your fingers? I take it they warp?, anyone had this problem before? Someone has had a go at the sealant already (as one of coils also had sealant on it).....
I did it but I wouldn't recommend using too much sealant in there, probably best to find another rocker cover, new if possible, but they were over $200 I seem to remember and would have to come from Japan. The plug tube seal isn't replaceable.
Awesome.......I wouldn't bother with a second hand rocker as mostly likely would have/will warp.....I am getting a few quotes on rockers covers now..... but this is money I would rather be spending on suspension or exhaust or on my race car......
Will report back with quotes
Edited by MOUTH
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
