Its just the way that they make Jap systems, unfortunatly. A Load of GTR owners have been caught out this way- Pay big Dollars for a brand name Jap system that states 90mm diam. or whatever, only to have the system taper down within the mufflers and restrict power. Genrally this is only happening at power levels >250kw.
This is what I'm going to test on my car- I think the exhaust might be holding it back. Checking is easy enough- run your car up on the dyno. Then remove mufflers / cats and run it up again. If there is a big difference, then you know there is restriction. Its always a pay off between noise and flow- it takes a good exhaust fab. to make a good flowing not offensively loud exhaust.
OP did say non-removable in the previous page. I couldn't figure out how to get it out from the pics- but I'd be looking!
This is an example of what I mean. The Lovely Fujitsubo exhaust that all of us M35 owners love. Have a look at the pipe diam. 76.3 (3inch) to 60.3mm (about 2.3inch) . Wat! I guess the nismo is about the same. Am I really trying to push 200kw through 2.3inch exhaust...?
Product Specs
Brand: FUJITSUBO
Product: Legalis R Exhaust Muffler Nissan Stagea NM35 Turbo
Part Num: 790-14933
Kit Includes:
- 1x Legalis R Exhaust Muffler
- 1x Gasket Packing
- 1x Gasket Ring
- 1x M10x20 Flange Nuts set
- 1x M10x35 Flange Nuts set
- 1x M10 Flange
SPECIFICATIONS:
Tip Tipe: Round Slash (W)
Tip Diameter: 94mm
Pipe Diameter: 76.3mm-60.5mm
Muffler Weight:
- OEM: 23.2kg
- Fujitsubo: 15.6kg
Intermediate acceleration (40km/h to 120km/h in 3rd gear)
- OEM: -
- Fujitsubo: 2.7sec
Maximum output
- OEM: -
- Fujitsubo: 197.0kw (267.9ps) / 5400rpm
Maximum torque
- OEM: -
- Fujitsubo: 431.2N/m (44.0kg/m)/2770rpm
Supercharging pressure:
- OEM: -
- Fujitsubo: 1.09kgf/cm2
Noise Levels (dB):
OEM:
- Idling Sound: 60
- Noise Near exhaust (5850rpm): 81
- 3000rpm: 72
- 5000rpm: 81
- Response 4000rpm~6000rpm: 96
Fujitsubo:
- Idling Sound: 66
- Noise Near exhaust (5850rpm): 86
- 3000rpm: 80
- 5000rpm: 85
- Response 4000rpm~6000rpm: 105
COMPATIBILITY NOTES:
- Only for Turbo vehicles
Pretty sure it would be 3". Remember that each tip is 94mm, so considerably larger than the exit point of the muffler
http://www.kakimotoracing.co.jp/image_n31359.html
http://www.nengun.com/kakimoto-racing/inner-silencer
Note the external daimeter.... just sayin'
Did you look in the back end through to the twin tips?
I don't think thats 3 inch, not that I can get in there and measure it.
Bah! I forgot you had the Nismo one like I did. I was referring to the Legalis tips.
I thought that the Nismo muffler's exit hole was closer to 2.5" at first glance, but didn't measure it either.
Pretty sure that the Legalis' was larger (3") and I can't imagine they would have a smaller point to the tips than the inlet of the muffler...
My God that sounds shit
In your pic, is there a space around it? I can't really tell on this laptop with that pic
http://www.skylinesaustralia.com/forums/gallery/image/83088-kakimoto-full-mega-n1-rev-muffler-115mm-tip/
I'm not saying that it would restrict to 200 exactly. I am well aware that Cars running the legalis are well up and over that.
What I am saying is that any restriction will cause a loss in power, and their might be gains in looking into the exhaust for restrictions- durh, I know.
And I don't have the same exhaust as you. I have a Nismo- now I don't know if there are any signifigant differneces between the two rear mufflers in either system. It could be that the nismo runs a 2.5inch reducer in the rear can, while the legalis is bigger. Who knows?
Thats why I'm going to test it out.
The easiest way to check it to put a pressure gauge in line and check for backpressure; your cat might even have a blanking plug in it that you could use.
I have seen this style of silencer before, you should be able to slide a die grinder in there with a cut off wheel and just trim it out. It is manufactured into the muffler to help quieten it down.
You reckon i could cut it out - i don't think it would be easy. wouldn't there be insulation in the muffler round that smaller center pipe? if i recall it looks the same from both ends if i look down the muffler tip or on the incoming side
some more piks for a better look -
Muffler tip
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
