I will replace them with SMD lights after it passes the pits, Just to be safe.
But yes, it seems he just wanted to sticker me cos he could and knew i would pay it i guess... wasn't a good day for me.
Did this yesterday.
Finally got rid of my ugly pillar gauge holder and have setup the new one....only problem is I cannot see what gear I am in......not that I ever know with this retarded gearbox anyway.
Edited by Jetwreck
Dropped Moby off at AM Performance for the suction pipe, a job Andrew is really looking forward to after seeing how much room there is to work in.
Drive there was the first time I'd driven the car with the EVC fitted. It still needs some tuning. At first it felt very sluggish, until I worked out how it was setup. A change of the boost settings saw it return to almost normal, but it seems to be making boost a LOT earlier than it was. It's also measuring boost before the factory boost gauge hits about -0.25PSI.
Hoses aren't leaking though, everything is staying together, so I'm convinced it'll be a setup thing. Just need more time with it.
You getting 3 inch intake madness? He is going to hate you. lol.
:rofl:
I told him I'm half expecting a call telling me to bugger off.
Wasn't impressed when he looked where it had to go. Even less impressed when I mentioned it had to be 3"...
Why did you decide you couldn't make a jig in the end Scotty?
:rofl:
It's hard enough with my 2.5" pipe using a jig, and I have 10mm odd either side; the 3" would need to be absolutely perfect every time in every single dimension.
Love to see the finished article.
Thanks for the reply last night mate; very helpful. ;)
No worries mate, sorry I didn't get to take any pics today, was in a hurry. Puppy had to get to puppy school...
My intake won't have to be 'absolutely perfect' as I'm using a pod. SA doesn't have the same rules on induction as the eastern states.
I told Andrew to make up a jig, so we'll see what happens.
Finally got a new clutch fitted. Ended up with a DCS billet twin with ceramic multi button plates.
Pedal weight is lighter than the Exedy heavy duty I fried at WSID, It grabs a bit but nothing like the HKS twin I had in the car before.
Redline Shockproof in the gearbox and front diff.
Back to WSID next time i'm home to see what I can break next.
I have a jig, it is a spare engine and turbo. ;)
I have made a few and sent them interstate now. Way too hard to guarantee fitting accuracy with only a few mm of clearance though, and most turbo's being highflows they are all clocked slightly different. Can't be done very easily.
I can definitely make the lower and middle sections, then you need to cut your AFM to fit the top section to the airbox, something most people would be reluctant to do. Then, I can't supply the top part as it is in a slightly different spot every time I make one. There are also no bends tight enough to get a smooth transition into the turbo without lobster backing. With so many wedges of alloy to join there is a lot of welding involved.
The funnel to the turbo is the most critical part when it comes to power. If the hole is too small you waste power, less airflow. If it is too big there is a step which slows the airflow. Every highflow is a different size so you need custom parts made on the lathe = time and expense.
Besides all that, not many people willing to pay for the time consuming fitment process. (you had issues getting to the actuator, have you tried to get to the lower bolt on the intake?)
I would be keen to see what he can come up with mate, and for what cost. I think I was doing it for a very reasonable price considering the time involved in making/fitting them. I know of one owner that paid 3 times what I was asking at another shop.
I figured it was because I was a mechanical numpty that I got frustrated with the actuator...
Andrew's got the car for a few days, he'll take his time and we'll see how it goes.
That was the last thing I had to do on the car before the F-con sensors went in, and it got tuned. So shouldn't be long now. Just depends on whether I should get the TransGo kit in first.
At this stage I'm not 100% on the highflow route. That's something Andrew and I will have a chat about when I pick up the car.
So what sized hole is he putting in the intake at the turbo end? It's not something you want to do later once the intake is made.
The go would be to make it the full size of the metal gasket (opening to arrow). If the turbo is high flowed later they normally just enlarge it till that ramped part is gone. Well, that's how I made mine & how it came back from Stao. Didn't have to change a thing, thankfully.
It depends how big you go I guess, Craig's turbo compressor is much larger than that chamfer...
I'm pretty sure Ryan is after more response than laaaa (wait for it) aaag, & hence won't have that issue. :)
Oh no; haven't you heard? Non functioning numberplate lights are a leading cause of serious & fatal accidents in Australia!
:rolleyes:
Oh yeah, that must have been what caused the multi-car pile-up on the M4 today in/near Silverwater. Two trucks and at least two cars, it's a mess!
I saw pics of this; looks like I'll be going home on the M2/M7 today...
I heart tolls
Edited by Daleo
It's only lag till 3500-3800.....then is party time. ;)
I just purchased a spare standard turbo.....my current one is coming off in the near future for a service so I might see what I can get with a smaller rear housing setup......a GT30/?????
Edited by Jetwreck
I've left it entirely up to Andrew, he'll do what he thinks and I'm sure it'll be right to go. If it needs to be modified later that's not a big deal.
It's never a big deal when paying an hourly rate, lol.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
