It's only taken you a few years. :P
lol yeah yeah yeah. It's taken me just over a year, but it's been a busy year. Hopefully taking my time and doing it all properly pays dividends.
Adjusted the rear swaybar on the M35 today from the softest to the middle setting... Holy shit what a difference!
Would be keen to go all the way but I'm a bit worried the Mrs would accidentaly get it sideways around a roundabout in the wet & clip a gutter. :(
From memory those settings Alex listed were the Whiteline recommendations? Thats what I've got my car on and it feels great.
Why Cusco Zero2Rs? BC BRs deliver, and are cheaper?
Ordered my internal bits today: pistons, rods, head gasket, studs, pins, rings, head studs... Getting excited: it's all coming together: block is in getting honed and prepped, so will hopefully have it all screwed together next week...
That said, I imagine my tuner will be taking Christmas off, so I doubt I'll even have a run-in tune until mid January at the soonest...
Not what i have done but what i've found out:
you can now use google translate (at least on android) to translate photo's of text from jap to english!!!!
Pointed the phone at my fuse box, highlighted the text i wanted and bam! It told me what the japanese said and it made sense!
yeah, i downloaded it and printed it out
but its also useful for other areas where there is no known translation
or for areas of interest for the jap service manuals (r33/r34 etc)
Car was finally tuned yesterday. Bad day for it with the heat, but oh well.
We had issues with the config of the EVC to start with. For some reason it had started just delivering 7psi. By the end of the day it was fine and back up to 15psi, but it's pretty obvious that I'll need Scotty's upgraded wastegate spring.
Few things still to clean up on the tune but we'll get there.
looks good Ryan.
Seems like the shut if down pretty early- about 6000rpm. Stock turbo is out of puff anyway. Magic question - what was the AFM volts maxed at?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
