Great job but not entirely convinced it's in the correct area of the bonnet. I reckon positioned a bit more on the passenger side and higher would have it quite effective with heat extraction from the turbo area.
Any venting has to be better then none at all
finished venting bonnet today......Wing and Front bar to go!
Whale can has blowhole?
Lol Jokes, it actually looks pretty good, you've more stones than I have to take cutting tools to your bodywork
My bonnet is stuffed anyway.....and there also might be some vented ones getting made very soon so to me it was a no risk!
I would not have done testing on a good bonnet.
so if i'm correct this will be cleared by custom's and getting sent up this week, if it's not being too hopeful...............!!!!!
** also i dont know if it can be viably made for under $1000 each but i'll get the ball rolling once i get my hands on it **
Edited by WAGON_BOY
nice ;)
Put in the new intercooler today made a diffrence driving around in this crazy heat.
thought it was going to be a prick to install but it went in nce and easy.
HDI Intercooler? Yeah not too hard to do, just need to think about it and lubricate the silicon.
Do want. Carbon or Fibreglass?
Pulled the head off my Stag on the weekend. Did the head gasket. Not sure what happened. It's an RS4(S?) with 103,000km on the odometer, but I think it's been wound back somehow.
Blew the gasket on cylinder 6 into both the oil and water galleries, and it was starting to let go on cylinder 5.
As soon as the temp gauge started to rise, I pulled over and had it towed. Fingers crossed the bearings are fine, as the oil is quite milky.
Planning to have it back together this weekend coming providing parts and head machining aren't delayed!
These arrived at work on Friday for me and I've got myself booked in for this coming Friday to get them fitted
Wrapped in a set of these (They're Falkens, to add some fuel to the Nitto vs Falkens debate :P)
At the same time I'm getting the coilovers fitted AND the bushings kit from the group by. Basically, its christmas.
Oh, and I played the 'jump start your car because the battery is too flat to charge' game on the weekend too.
That must make it Adelaide cruise time! There are a few people keen for a Feb cruise.
I did really exciting things to my car: I retuned the throttle. *YAWN* Feels better though.
Falkens? I read somewhere in a thread that they're pretty good.
Nice wheels btw, :woot:
Finally got an alignment!
Toe was massively out, even on the rear (which wasn't altered at all)
and the place i used actually found more things wrong than when i got the pedders check, so i doubt i'll back there in a hurry
most annoyingly tho, they didn't touch the new adjustable bushes and said there is something wrong with the caster bushes because they aren't stock
good news is that caster is up to about 4.5-5mm and its sitting on 1.5-2° of camber in the front
Will have to give them a call about the superpro bushes and see what they think is wrong
Who did u go to?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
