Great job but not entirely convinced it's in the correct area of the bonnet. I reckon positioned a bit more on the passenger side and higher would have it quite effective with heat extraction from the turbo area.
Any venting has to be better then none at all
finished venting bonnet today......Wing and Front bar to go!
Whale can has blowhole?
Lol Jokes, it actually looks pretty good, you've more stones than I have to take cutting tools to your bodywork
My bonnet is stuffed anyway.....and there also might be some vented ones getting made very soon so to me it was a no risk!
I would not have done testing on a good bonnet.
so if i'm correct this will be cleared by custom's and getting sent up this week, if it's not being too hopeful...............!!!!!
** also i dont know if it can be viably made for under $1000 each but i'll get the ball rolling once i get my hands on it **
Edited by WAGON_BOY
nice ;)
Put in the new intercooler today made a diffrence driving around in this crazy heat.
thought it was going to be a prick to install but it went in nce and easy.
HDI Intercooler? Yeah not too hard to do, just need to think about it and lubricate the silicon.
Do want. Carbon or Fibreglass?
Pulled the head off my Stag on the weekend. Did the head gasket. Not sure what happened. It's an RS4(S?) with 103,000km on the odometer, but I think it's been wound back somehow.
Blew the gasket on cylinder 6 into both the oil and water galleries, and it was starting to let go on cylinder 5.
As soon as the temp gauge started to rise, I pulled over and had it towed. Fingers crossed the bearings are fine, as the oil is quite milky.
Planning to have it back together this weekend coming providing parts and head machining aren't delayed!
These arrived at work on Friday for me and I've got myself booked in for this coming Friday to get them fitted
Wrapped in a set of these (They're Falkens, to add some fuel to the Nitto vs Falkens debate :P)
At the same time I'm getting the coilovers fitted AND the bushings kit from the group by. Basically, its christmas.
Oh, and I played the 'jump start your car because the battery is too flat to charge' game on the weekend too.
That must make it Adelaide cruise time! There are a few people keen for a Feb cruise.
I did really exciting things to my car: I retuned the throttle. *YAWN* Feels better though.
Falkens? I read somewhere in a thread that they're pretty good.
Nice wheels btw, :woot:
Finally got an alignment!
Toe was massively out, even on the rear (which wasn't altered at all)
and the place i used actually found more things wrong than when i got the pedders check, so i doubt i'll back there in a hurry
most annoyingly tho, they didn't touch the new adjustable bushes and said there is something wrong with the caster bushes because they aren't stock
good news is that caster is up to about 4.5-5mm and its sitting on 1.5-2° of camber in the front
Will have to give them a call about the superpro bushes and see what they think is wrong
Who did u go to?
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
