Haha, yeah but both unmodified and lightly modified I can confirm that the series 2 is a far superior car.
Only thing the series one has over it is power... but if you go into heavy modified versions of each, I would suspect that the series 2 would have it all over the series 1 there as well.
lol if you had spare 20K......then you might be bumping the back door of Scott's car!.......for 5K on an NM35 you'd be getting close too!
PNM35 is how much....I've seen NM35's for as low as 9K.
I drove a PNM35 on the weekend....it lack's power!.....newer is nicer as it should be but needs a lot more powerZ.
Might lack boosttzz and powerz but how well does it handle and brake?? :D.
Massive thanks to Craig in fitting my R34 brakes :D Has stopping now!!
Just press the pedal hard and it just fuggin stops. Eyes be poppin out of your head, choking on the seatbelt.
Looks awesome man. This is on the list for mine but it can wait.
I hear youve been calling my car a maxima alex.....? *flips table* but in all fairness it is called for since i call yours a murano
Cheers :D. You'll need em when you haz boostz.
not as good as mine!!!
Yea, but you got LSD n hicas with full adjustable BC's, just the three main things I won't ever have. :P also your car is a beast on four wheels.
Haha owned.
HA! heaps owned. So Brick, hows your handling going? :D Read somewhere you live around the northern beaches? Can't believe I haven't spotted you yet, I live in Collaroy before was Brookvale.
All I can really put some money into and expect better gains is in handling, which was all I was trying to say. :P
And the VQ25det was going to be so expensive to rework into something that would meet emissions standards that Nissan replaced it with the Camry-fighting n/a V6 from the Maxima which continued to be produced and developed in many models for many years....
wait. Thats the VQ35.
:P
Fixed
Haha, sensitive. Never said it was a dollar for dollar exercise, just saying that a throwing money at an NM35 vs throwing money at a PNM35 will result in the PNM35 giving the greater performance.
Yes, it will take less for the NM35 but I was referring to heavily modifying.
Also, to answer your question, you should be able to get PNM35's landed for around 11k although they will be around 150,000-180,000kms old (about the same age, or younger, than most nm35's prior to the magical wind back... just without the mechanical issues :P)
More power would be nice though... hmm, I seem to recall saying that with the NM as well so maybe it would just be a recurring thought regardless of where my car is at lol
landed is different to landed and complied!
....5K on and NM35 is going to go a shit load faster and have greater economy than on a PNM true or false?
There will soon be a heavily modified NM35 from Mercury Motorsport smashing PNM35's like glass bottles against a wall!!!......mind you it would matter if you put that driveline in the NM or PM because other than the dash it would still be the same car.
BAM!!!!
Also forgot to add the part about being in the top 10 ward's BEST engine list for 4 years. :D
Can't see VQ25DET anywhere in there?? How could they miss that? xD.
LOL...cognitive dissonance much? You do realise that the Ward's list is based only on USDM cars...
wont contest that.....VQ is a good design. Doesn't matter what variant either.
BUT!!!! Show me the POWERZ!!!
Im sure if the VQ25DET was in production for the same amount of time the VQ35DE has been i'm sure it would have been.
The 25DET is much the same as the 30DD in the sedans in the fact that it was only in production for 3/4 years and mostly got pushed aside from the hype of the 35DE and didnt really get to show its potential.
BAM!!!!
That thing is huge!
4.2 stroker, GT62, hnnnnnnngggghhhhh! :woot:
I'm sure once I get around to bolting up my sway bars it will handle pretty good. TBH though I'm bot that unhappy anyways.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
