that's about the standard boost mate....is the boost controller turned on? generally it would be set between 12 and 14psi for a standard turbo :teehee:
oh really? I was told by a few people that standard they are meant to be set at about 7psi and 10psi is the 'safe' boost to run daily on stock turbo. Boost controller is turned on, but i haven't tried playing with it yet. Need to download and read the manual :/
Blowoff valve and wiring loom for ignition coils arrived today! Wuhoo! Off to mech on Friday to have it all fitted up, then as soon as my tuner has time, we'll give it the 5th "final tune", and everything will be awesome (probably wishful thinking given the epic issues, but you gotta stay positive, yeah?)...
Sounds like it should all be sorted :) it's good you got back on the horse, it can be really detering when these things happen.
I remember someone asking for a picture of my seat because we were bidding against each other months ago. So here it is.
Wow cool seat!
Update on our stag. We put a new fuel pump in (walbro) then started getting a hesitation on take off and light throttle. Checked voltage at the pump on idle and revs. 9 volts!! Haha didn't really want to run a new power cable etc so at first I was like il try earthing the fuel pump direct to the chassis and see what happens.
So did that and check voltage. 12.2 volts. Sweet! Went for a drive and the hesitation was gone!! Yay
Car went on the dyno again and made 180kws at all four wheels. Goes much harder now, wow haha
good to hear that it was a simple fix, but you need to be a little careful with just putting it straight to the chassis. Does the fuel pump still turn off after a few seconds when you turn the ignition on (but do not start the car?)
In a lot of these systems the ECU uses the earth to turn off the fuel pump when the ignition is on but the car does not start.
If your fuel pump does not turn off (may be hard to hear), you need to add a relay where pin 85 goes to the original ECU earth to the fuel pump (12v can come from any ignition switched source to pin 86). Then connect the old fuel pump earth to pin 30 and pin 87 then to the chassis earth.
What have I done to my Stagea lately??
Nipped in to town to do some shopping!
All this gear in the car and still could of beat any Commondore!!!
Sent from my HTC One XL using Tapatalk 2
hay
What have I done to my Stagea lately?? Nipped in to town to do some shopping! All this gear in the car and still could of beat any Commondore!!! Sent from my HTC One XL using Tapatalk 2
That's quite a bit of stuff is that shopping for a couple of months!
Gktech open ended wheel nuts on order, once they arrive I'll start playing with my spacers :-)
Managed to pick up two pairs of their 15-30mm spacers for $150
Should be able to fit my kakimotos over the front brakes now
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
