Ok sweet what's his number Josh and what's parts is he making you out if interest?
+61 414 879 711 currently he is making me a custom idle control unit for my cable throttle setup
So i've had a chance to drive the M35 for a few days since getting it back from tuning.
My main observations it that i'm already driving a lot heavier footed when i want the car to come on boost due to the lagg but i'm really enjoying it. The car sounds amazing as it hits boost with the increased air flow however i really need to do something about the exhaust. 3 inch stainless with front / dump and Apixi N1 cannon is simply way too loud for me. Not sure what i'll do but a bit of forum trolling will hopefully find an answer.
Overall i'm very happy. Big thanks for those that helped along the way.
All that's left once i sort the exhaust is doing something about the front bumper (this stocky one with the parking aid has to go).
  • Like 1
I find my varex is too loud for me at times as well even with an xforce resonator so im looking at switching to a HKS silent hi power muffler to try and get the system quieter. It will eliminate the lower pressure in cabin sounds. I also find that the exhaust can have different db notes from bearable to unbearable at times.
Had a minor o-ring issue with the access to the fuel tank and the M35 was leaking fuel after a filled the tank up but all is fixed and it's perfect once again.
I got the muffler replaced today with something a little more appropriate sound-wise. Still 3 inch straight through but more factory looking. Much quieter than the Apexi N1 and the drone is much more tolerable :laugh:
  • Like 1
looks good mate! Can I ask where you got those LEDs from?great fit
Just some cob leds off ebay you can get wireless (RF) ones that can chage colour lol. http://www.ebay.com/sch/i.html?_odkw=cob+led&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xcob+led+halos&_nkw=cob+led+halos&_sacat=0
Cool man what diameters did you use
60mm for the park 70mm for the indicator and 165 for the main lights if i was to do it again i would use a yellow/white 2 colour ring for the indicator signal led (has 2 positive wires and one negative) so it it will change colour depending on what cable you put power on, so it would flash yellow with the turn signal. other than that you probs just need a dremel to cut into the the plastic silver surround inside the headlight. headlights come apart just like normal. oven,heat gun or blow torch to warm up the silicone like rubber stuff then pull apart.Also depending on what look you're after you can get different types of leds just make sure its a cob led ring if u want a more solid ring of light!
  • Like 2
fantastic cheers mate ill look into that
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
