On 21/09/2016 at 7:23 PM, Moistcat said:
Painted my D pillar trims
Before (got the car like this);
After
Done with rattle cans made up with the colour code AR1
Sneaky Chopped Sticker i see lol
Upgraded ARX brakes with R34GTT brakes and V35 wheels.  Pads not bedded in yet but it feels way better than the slotted and dimpled rotors and EBC reds that were there before.Also replaced the AFM to resolve the issue with the intake let temp sensor (code P0110).R34GTT brakes on ARX.jpg
  • Like 1
What Have I Done To My Stagea Lately?
Sold it :(  Now i'm sad..
If anyone wants a woodgrain head unit fascia (single zone aircon, 6 stack CD) in good knick then let me know - free to good home (Brisbane collection)
Finally got around to "fixing" something that has bothered me since I've had my M35. The beeping when you have your keys in the ignition with the door open. I know it's a safety thing but I often sit in my car with the door open listening to tunes or for when you are working on the car with the door open. I just took out the little disc from the dash cluster buzzer.
  • Like 2
What Have I Done To My Stagea Lately?   Sold it [emoji20]  Now i'm sad..
Ill take it man. (Assuming its for a m35). Shoot me a message.
Thanking you. Always wanted to rip this thing out.
A few parts to fit on the weekend. Left front balljoint, right rear bearing and rocker gaskets (I'm over that burning oil smell).
Also broke an injector pintle when doing the coolant bypass mod so going to do new o-rings, pintles and intake gaskets which were looking a bit ratty.
  • Like 1
where you get those bits for the injectors?
Fitted most of these bits over the weekend. Ball joint, PITA! Rear wheel bearing, PITA! Rocker gaskets, small PITA! Injector pintles and o-rings, OK.
Then it came to the intake manifold gaskets. Plenum gasket, "hang on, that looks a bit different to mine". Check my part number: Stagea, check. VQ35DE.........crap!
That's ok, the original one isn't THAT bad. Better check the intake manifold gaskets. Stagea, check. VQ25DET, check. Off with the intake manifold, "hang on, they look a bit different"...........crap!
So going by the permaseal website, these ARE for VQ25DET: http://www.aagaskets.com.au/EngineDetails.aspx?EngineID=2327
These ones are different again to VQ35DE so was there different port sizes on VQ25DET?
That'll learn me not to buy genuine!
When I do get the right parts I think I'll do the plenum spacer mod at the same time.
On a side note, I found a dude in Russia who turboed his 350GT using VQ25DET parts.
http://www.nismo-club.ru/forum/index.php?showtopic=143220&st=0
  • Like 1
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
